Author Topic: Clutch Squeal  (Read 2666 times)
Urbestfriend
Clutch Squeal
« on: June 19, 2010, 01:15:34 AM »
Have developed a momentary clutch / belt squeal when taking off (especially fast).
Pulled everything apart 2 weeks ago and cleaned everything,  but did
not roughen up the sheave faces.  Two or three days later,  it started
back up.  Unfortunately the manual does not present anything about
this malady.
Re: Clutch Squeal
« Reply #1 on: June 19, 2010, 01:47:35 AM »
..how many kms do you have on your belt??
Re: Clutch Squeal
« Reply #2 on: June 19, 2010, 07:20:17 AM »
A stiffer contra spring will add more pressure to the belt, and one of the Malossi, or gates kevlar belts will not stretch
Urbestfriend
Re: Clutch Squeal
« Reply #3 on: June 19, 2010, 02:09:50 PM »
Under 3,000 miles doesn't seem like enough to be te belt.
Although it could be.  The manual says to scuff the sheave
faces with 600 grit sandpaper.
Hoolander2
Re: Clutch Squeal
« Reply #4 on: June 21, 2010, 02:31:28 AM »
Have you seen the thread under Xciting 500 titled something like "Does your Xciting growl"?  There're a lot of ideas there.  One in particular where the clutch bell was drilled with a few small holes to let the dust out.
Urbestfriend
Re: Clutch Squeal
« Reply #5 on: June 21, 2010, 09:58:28 PM »
Hoolander...Urbestfriend says "Thanks for this tip."  It was well into the list
and addresses the same exact issue.  Today I rode the whole 11 miles from work
and didn't have one episode.  (Didn't stop but once or twice.)  Brings me to the
conclusion that more active riding,  stops,  starts,  etc. will cause the noise.
Currently...I am comparing the parts list for both tis bike and my Grandvista.
Many of the same parts seem to be used on either model.  It's always a good
investment to have common replaceable parts in your stock.
Re: Clutch Squeal
« Reply #6 on: June 21, 2010, 10:48:46 PM »
It's always a good
..YES IT IS...
..I BOUGHT A JUNKER MARSHIN JUST FOR THAT REASON...
..ALREADY PAID FORITSELF WITH BRAKE PADS AND A STARTER MOTOR...
