Author Topic: tire chains  (Read 3604 times)
airshot
Re: tire chains
« Reply #15 on: December 19, 2016, 02:10:39 AM »
    Thanks for the pics, sure looks like a fun place to do some trail riding.  It appears your giving the chains a good test!!
Re: tire chains
« Reply #16 on: January 27, 2018, 07:33:17 PM »
my Trygg chains have become invaluable after an ice storm we had last week. Had to pull my log splitter up an icy 25% grade to get to my wood pile, no problem, didn't spin a wheel
« Last Edit: January 27, 2018, 07:51:13 PM by randyo »
Re: tire chains
« Reply #17 on: January 04, 2020, 11:41:57 PM »
3 year update
chains are still tight with no slack,  getting regular use, I built a wooden drag plow(angle iron on leading edge) cuts down dramatically on my snowblowing time, I keep a couple trails (about 1000 feet total) open
well worth what I paid, few people told me I was crazy and I could get em at Walmart for 1/3 the price
these chains will last longer than the 450i
airshot
Re: tire chains
« Reply #18 on: January 06, 2020, 03:41:00 PM »
Thanks for the update, glad to see they are working well.  Did you put these on all 4 tires or just the rear ?. Pics are to small for my old eyes to see.
Re: tire chains
« Reply #19 on: January 07, 2020, 04:05:16 AM »
all 4,  they are on their own set of wheels, swapping a set of wheels is a whole lot easier than taking the chains on and off
Re: tire chains
« Reply #20 on: January 22, 2020, 03:29:16 PM »
You can see my drag plow off to the side, I adjust the length of the tow chain from each side, to wing the snow to one side,
I have my otter sled hooked up to pack the snow in the center of my trails
airshot
Re: tire chains
« Reply #21 on: January 22, 2020, 11:52:50 PM »
I wouldnt want to install the chains each season, smart move getting extra set of wheels and tires was the way to go. Is that drag pointed or just looks like that in the pic.  Do you use your drag on gravel or just snow?  I have a long gravel drive and your giving me an idea.
Re: tire chains
« Reply #22 on: January 23, 2020, 12:55:58 AM »
it is an equilateral triangle 6ft on each side, the 2 leading edges have 2" angle iron as a cutting edge, the front point is protected with sheet metal, the post has a eye hook near the top on each side, for hooking bungees that keep the slack tow chain from dragging when I shorten the other side to angle it to wing snow to one side.
I make my first pass casting equally to both sides, then I angle to continue casting snow over on one side. It takes me 4-5 passes to clear a 12 ft width in a 6" snowstorm, deeper snow I have to get more creative, making a couple V passes, leaving a bank in the center, then winging that bank to one side
then I clean up what I can't get at with my snowblower
