Author Topic: CHANGING THE DRIVE CLUTCH  (Read 876 times)
feebleknievel
    • Kickin Country hITS
« on: December 08, 2016, 09:52:12 PM »
NEED A clutch spring compressor tool ANY IDEA WHERE I CAN GET 1 OR OTHER DIEAS TO TAKE THIS CLUTCH DRIVE APART TO CHANGE THE RUBBER SEALS  THANK YOU
Mr. Paul
Re: CHANGING THE DRIVE CLUTCH
« Reply #1 on: December 08, 2016, 11:02:40 PM »
You don't really need a spring compressor tool to take the clutch apart. I put the clutch on the ground and compress it on one side with my knee or foot while compressing the opposite side with my hand. I then just unscrew the nut and release the pressure. It does have a little force, but not a tremendous amount. As far as removal of the large clutch nut, here is a link to the method that I have used many times. Works like a charm.
2009 Kymco People 150
1993 Honda Helix
feebleknievel
« Reply #2 on: December 08, 2016, 11:53:18 PM »
Thank you and that worked out just fine it's always appreciated.:)
Mr. Paul
« Reply #3 on: December 09, 2016, 10:48:28 AM »
1993 Honda Helix
