Author Topic: Led light bars for uxv 450i  (Read 3387 times)
Kames115
« on: December 11, 2016, 04:03:19 AM »
Looking at putting a led light bar on my uxv 450i. Was just curious what wattage I could go up to without drawing to much power. Was thinking light bar in the front and a couple little lights in the back. Any help would be great. Thanks!
airshot
Re: Led light bars for uxv 450i
« Reply #1 on: December 11, 2016, 03:35:57 PM »
    Just curious as to why the light bar??  I have found the factory headlights to be very good, never had an issue with not being able to see quite well. Not sure I would want to strain the existing system, in other posts guys that have added light bars on other machines have installed a second battery. I do some night riding in my area and have never found the need for additional lighting. So just curious here.....
Kames115
« Reply #2 on: December 11, 2016, 06:36:54 PM »
Just looking for a bit more light for plowing with. Was looking to mount it on the roof so it's easier to see over the plow.
SuperHeliDave
« Reply #3 on: January 01, 2017, 01:47:03 PM »
I put a 20w (6200) lumen LED bar on my roof for plowing, What a difference. Direct wire to the battery through a fuse, works great... used an open switch hole on the dash. Only shot it I had.  :-\
It can always be climbed.....
airshot
« Reply #4 on: January 01, 2017, 04:35:59 PM »
Yep like that idea of direct wire to the battery with a fuse, no sense overtaxing the electrical system of the buggy. Have you ever run out of battery power with that set of lights?
SuperHeliDave
« Reply #5 on: January 01, 2017, 05:10:40 PM »
Nope, it does not draw enough, and i usually do not need it for long..
jew8201
« Reply #6 on: January 01, 2017, 08:52:06 PM »
That looks good! What roof and windshield do you have?? Are you still running the stock battery??
airshot
« Reply #7 on: January 02, 2017, 02:14:52 AM »
    I just now saw the pic, I was expecting a larger light bar...how bright is that thing? Was it really worth the time and trouble...do you really get that much more light?
jew8201
« Reply #8 on: January 07, 2017, 04:43:48 PM »
Anyone know the specs on the stock OEM battery?? How much can it handle???
airshot
« Reply #9 on: January 07, 2017, 05:00:36 PM »
    Just looked at mine as I was wondering what I woud need when it comes time to replace it. So mine is rated at 18ah. According to the factory manual it states 12v 18ah, full chg at 13. - 13.2v, do not drop below 12.3 before recharging.
jew8201
« Reply #10 on: January 07, 2017, 05:37:42 PM »
So could the battery handle any additional lighting if one so desired to put any on without any complications of overloading the electrical system and battery??
« Reply #11 on: January 07, 2017, 05:54:31 PM »
its not the battery that you consider, its the output of the charging system, iirc, I read somewhere it is 310 watts, subtract from that howmuch it takes just to run the UTV, (electric fuel pump is probably the biggest user) at least with a UTV, lights are not always running like on a motorcycle
20±watts for a LED light bar shouldn't be a problem
jew8201
« Reply #12 on: January 07, 2017, 09:24:28 PM »
So a 20 watt LED light bar is all that should be used to be safe?  That doesn't leave a lot of choices in lights
airshot
« Reply #13 on: January 08, 2017, 03:39:05 AM »
    If you read on other forums about guys mounting serious lighting on there machines they go with dual batteries. I have found the headlights on this machine are fine, better than any light on any atv I ever had. I have found out that you can replace the factory headlamps with silverstar bulbs for autos. I have them in my car and they are really brite, thinking about adding them to the Kymco.
jew8201
« Reply #14 on: January 08, 2017, 05:02:46 AM »
If you add a dual battery, you mean another ATV battery or a car battery? And where would you put it? I like a LED light bar not gonna lie. I dont know that they're necessary, but they are "cool". Thats good to know that the silverstar bulbs will work. I have ran them in my trucks in the past. Whats the part number for the bulb?
