Author Topic: Led light bars for uxv 450i  (Read 3377 times)
SuperHeliDave
Re: Led light bars for uxv 450i
« Reply #15 on: January 10, 2017, 06:07:18 PM »
Sorry, I have not been on in a while, the bar is 6500 lumens, sometimes too bright, I did not run a Dual battery, don't think it needs it. The roof is just a fits all from Cabelas, the windshield is homemade. From a sheet of lexan.
It can always be climbed.....
jew8201
« Reply #16 on: January 10, 2017, 07:38:51 PM »
Ok, thanks SuperHeliDave. Where did you find your light bar?? There is not a lot of choices out there for low wattage lights. I was debating putting two cubes on the lower front bars on the roll cage and maybe one small light on the back for messing in the bed or when backing up at night. Of coarse I may end up not doing any additional lights, but I like the thought and idea of it. I will more than likely just strap a battery powered LED inside and maybe point one shinning into the bed as well. And as airshort said maybe swapping the bulbs with some silverstars.
