Author Topic: air mixture screw  (Read 1584 times)
marioG
air mixture screw
« on: June 19, 2010, 12:42:42 PM »
can anyone check original place from tightened to lose..
ive got 1.75 turn....but it is too rich mixture, reading from plug...
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
axy
Re: air mixture screw
« Reply #1 on: June 19, 2010, 02:57:11 PM »
They have to be set to fit all environments, altitudes, moisture in the air etc, and considering it is much better to run a bit too rich than a bit too lean, almost all carb vehicles are set to be a bit too rich.
Personally, if everything else feels fine, I could not care less.
Kymco Agility 125 2008
marioG
« Reply #2 on: June 20, 2010, 05:09:36 PM »
agree,
but now dont know is it wright....
art
« Reply #3 on: June 20, 2010, 06:13:47 PM »
Hey G the idle mix screw only affect your carb at idle has no real affect after idle your rich condition is most likely a dirty airfilter or if you have been moding your carb the main is to large.Try a clean filter and new plug if still rich clean the carb.To set your idle turn mix screw in all the way then out while running untill you get the highest idle than back the screw off 1/4 turn.Hope that does it.1 1/2 turns are close to factory,but your envirnment can make this change,so your setting whats best for you where your at right now.
