Author Topic: what have you done to your yager today,?  (Read 10142 times)
Mr. Paul
Re: what have you done to your yager today,?
« Reply #30 on: July 30, 2017, 09:21:44 PM »
Glad you got her running well again Dedee! Hope the weather is nice up your way.
2009 Kymco People 150
1993 Honda Helix
Louder North
« Reply #31 on: August 30, 2018, 01:48:39 PM »
8 30 am.  shot ride 20 Km.  got home and drain the oil , changed the filter used magnet to get the little spring in place, works perfect,.  copying yager 200  I put that slippery stuff in the oil,  shake foe 10 min.  and pore it in,  and go for a long ride 250 Km.s should do it,.  boy does it make a big difference,  smooth engine real fast, bike needs a new coil so I can try for high speed run, ordered new coil from dealer $ 167.47 got the right # and checked on line $ 58.25   from powersportswarehouse.com    I let it go to the dealer for once,.  2nd time I got something from the dealer in 5 years, not a good customer,.  too bad,  but I cant afford him on my pension,
de dee:  How did you know you needed a new coil?  Did you have an error code?  I might need one too and was wondering what the symptoms are....
thanks
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
« Reply #32 on: September 01, 2018, 07:14:50 AM »
I was checking for codes with the diagnostic tool,  there was a few of them ,so I cleared them and tried to see what would happen with engine running and it started up and seems to run smoothly, I will have to ride it for a few miles to check it out to see if it goes back to missing,   WHAT DID I DO,!!!????  TO MAKE IT RUN SO NICE,
« Reply #33 on: September 03, 2018, 07:26:07 AM »
  I have been reading about the diagnostic tool,   cyclepedia has a different one mine is a kymco unit,  and the read out is not the same,.
