Author Topic: Kymco LIKE air filter hose  (Read 1411 times)
PaulF
« on: December 18, 2016, 09:45:36 AM »
I checked my air filter and when I removed the side panel I noticed that the end of the air filter hose was hanging and not attached to anything although there seems to be a slot (circled) where it would connect onto something. Should it be connected?   Also, the foam layer of the filter was falling off as the glue holding on to the filter was barely there.
Re: Kymco LIKE air filter hose
« Reply #1 on: December 18, 2016, 02:50:59 PM »
  the other end of the tube is attached to the air filter box, this end is behind the tupper ware feeding in clean air ,on my downtown and frost - yager they both just hang there,.
paceneedsstides
« Reply #2 on: December 18, 2016, 04:34:41 PM »
yeah its just a snorkel to bring in fresh air
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
ole two wheels
  • ole two wheels
« Reply #3 on: December 22, 2016, 03:49:22 AM »
That area you circled probably has a little tab on the side panel or frame that slides thru it to keep it from rattling and flopping around. If you can't find the tab, you can just wire tie it to any place. They hide the fresh air induction hose inside to restrict as much foreign matter, as possible, from entering the air cleaner box.
Mac, aka "ole two wheels"
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
PaulF
« Reply #4 on: December 22, 2016, 04:09:24 AM »
Cheers, thanks for that.
Paul
TroutBum
  • 2012 Like 200i (sold)
« Reply #5 on: December 22, 2016, 08:10:44 PM »
On my Like the snorkel just hangs loosely behind the plastic to bring in fresh air. Seems the placement is well thought out as I go thousands of miles and the filter is as clean as the day I replaced it.
Motorfoon
« Reply #6 on: January 10, 2017, 12:55:16 PM »
Ditto
PaulF
« Reply #7 on: January 10, 2017, 08:56:24 PM »
Thanks for the replies,
Paul
