Did you miss your
activation email
Technical | How To
need help - Auxiliary lights installation
Topic: need help - Auxiliary lights installation (Read 546 times)
Rafterman
Newbie
December 30, 2016, 01:11:57 AM »
Good day. I need some help i was planning on a little diy on installing additional lights for my S8 125 the problem is i dont know where to connect the wires.can someone help me with a wiring diagram.thanks a lot.
2011 300i downtown 82,265 KM.
Re: need help - Auxiliary lights installation
December 30, 2016, 01:57:44 AM »
if you are hooking up spot-lights to add to the headlights , I would hook up to the headlight wires,. low watt LED lights , adding to the rear, hook up to the tail light wires, not the brake wire, and keep track of the total wattage, keep it low,.
ole two wheels
ole two wheels
December 31, 2016, 02:54:18 PM »
I just added a strip of LED's to the rear of my DT300i. I went straight to the tail light/stop light socket
and removed it, so I had room the connect the LRD wires, using the single wire clamp on connector. The solid brown wire is the tail light wire and the green w/stripe is stop light and the solid green is ground. Haven't added to front lighting. As de dee said, keep your drain on the system as low as possible. LED strips require very low wattage. Hope this helps.
Mac, aka "ole two wheels"
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
Back
