Did you miss your
activation email
Battery size difference 200 vs 125 LIKE
Topic: Battery size difference 200 vs 125 LIKE (Read 2143 times)
PaulF
January 01, 2017, 04:41:23 AM »
Although my LIKE is not that old the battery died in it yesterday and I ended up getting a replacement but curious as to why the recommended battery according to the specs sheet is a 12V7AH for my 125 LIKE but the 200 comes with a 12V9AH. The recommended 125 battery is only 6AH and the measurements are 150L, 87W, 93H.
Also, there must be a trick to kick starting a 125 LIKE as I have tried many times (yes with the ignition on) but cannot get it to fire up. UPDATE: got it to fire up today 1st kick so I don't know what I did before that was wrong.
Last Edit: January 01, 2017, 07:43:01 AM by PaulF
beermak
Sr. Member
Re: Battery size difference 200 vs 125 LIKE
January 01, 2017, 11:11:16 AM »
If you want to fit a larger battery you need to cut the battery cover. In the inner side theres a plastic that holds the battery... you just chopp it and fit the larger.
Enviado desde mi iPhone utilizando Tapatalk
PaulF
January 01, 2017, 11:41:51 AM »
Thanks mate. I did read Stig's battery upgrade thread but just curious as to why they went with a smaller capacity battery in the 125 as aren't all the electrics and spark plug the same as the 200?
2011 300i downtown 82,265 KM.
Reply #3 on:
January 01, 2017, 05:29:43 PM »
]]] if they can save $ 1.00 per scooter and sell 1,000,000 units , think about it,.
big blue
Reply #4 on:
January 01, 2017, 06:07:40 PM »
I think it could be the fact that the Like 200i is fuel injected. The electric pump needs more reserve power especially at start up. On the starting issue have you checked the function of the auto enrichment device?
Last Edit: January 01, 2017, 06:22:46 PM by big blue
beermak
Sr. Member
Reply #5 on:
January 01, 2017, 07:51:59 PM »
The 200i needs a battery with charge to start. Needs to get the ecu and the fuel pump on asides the strter. Thats why it doesnt have the kick start of the 125. A 200i without battery need s to be cable jumped or a charged battery.
The 125's kick start is straight forward. Use the center stand. Turn ignition on and give while kicking.
PaulF
Reply #6 on:
January 01, 2017, 09:59:11 PM »
Thanks guys. Just one more question though, does having a bigger battery make it less strain on the alternator when riding with the headlights on at all times. eg, when just idling at a set of traffic lights.
Paul
Last Edit: January 02, 2017, 05:00:53 AM by PaulF
Reply #7 on:
January 06, 2017, 09:08:32 PM »
you could check the battery voltage at idle, and rev it up and check again, to see how much your stator puts out, that will let you know what your scooter needs to run ,. the larger battery has more amps to help start , more reserve,.
Back
