Author Topic: ..riddle me this...  (Read 3460 times)
..riddle me this...
« on: June 20, 2010, 01:11:37 AM »
..ppl will idle fine...
..when i squeeze either brake lever, or press the "passing" headlamp switch, idle increases, and will continue to increase until i release whatever it is i'm squeezing or pressing...
..rpms will not increase unless i am holding either brake lever or the headlamp switch..
..i can rev the hell outta it as long as i'm doing that...
..what the f*ck!!!!!!!!!!!!!!!!!!!!!!!
« Last Edit: June 20, 2010, 01:14:52 AM by wordslinger »
art
Re: ..riddle me this...
« Reply #1 on: June 20, 2010, 01:26:08 AM »
You got me they usually tend to do the opposite on the break pull,lights should have no effect or a drain at best,some more connections to clean?
« Reply #2 on: June 20, 2010, 01:30:49 AM »
...added note, the headlamp or tail-lamp will not burn at idle...
..squeezing a lever, brake lamp burns..
..press the "passing" button..headlamp burns..
..and in both cases, idle increases...
..i think my carb's just fine...
art
« Reply #3 on: June 20, 2010, 02:21:24 AM »
Your still going to want to take a look at it,the electrical stuff is kinda wierd,to effect the idle.Lotta juice being drwn somewhere
« Reply #4 on: June 20, 2010, 02:22:21 AM »
...i dunno...runs great as long as i hold the brake!!...lol..
0BARK4322
« Reply #5 on: June 20, 2010, 02:41:14 AM »
HUMMMMMMMMM--- YOU HIT THE BRAKES/FTP AND MORE CURRENT FLOWS
ALL STOCK
« Reply #6 on: June 20, 2010, 02:44:59 AM »
...orrr..with the tail-lamp and headlamp not burning at idle, current is being reduced, due to a faulty component...
..rectifier???
...i'm studying the schematic, but have yet to figure it out...
« Last Edit: June 20, 2010, 02:58:43 AM by wordslinger »
sidthesloth
  • Kymco ZX50
« Reply #7 on: June 20, 2010, 08:37:51 AM »
This wouldn't be caused by a bad earth connection would it?
InfernoST
« Reply #8 on: June 20, 2010, 09:49:46 AM »
You mean system ground not earth ground, correct? ;)
-Keith-
sidthesloth
  • Kymco ZX50
« Reply #9 on: June 20, 2010, 10:52:07 AM »
Yes, sorry.
0BARK4322
« Reply #10 on: June 20, 2010, 01:16:34 PM »
DO THE VOLTAGE INCREASE WHEN YOU HIT THE BRAKES
ALL STOCK
« Reply #11 on: June 20, 2010, 08:48:32 PM »
..haven't had time to check anything today...
..slept late, then my girls took me out on th' town...
..then we came back home and watched Kick Ass...
..been a good day.....
 ;D
« Reply #12 on: June 21, 2010, 10:20:01 PM »
..figured it out...
..the flasher relay had rubbed into a pink wire that goes to the bottom of a component that i'm not familiar with...
..looks like an H with the left leg taller....has a green wire on the bottom of the left leg..
...headlamp and tail-lamps still don't work, but the weird idle problem is gone...
« Last Edit: June 21, 2010, 10:26:43 PM by wordslinger »
art
« Reply #13 on: June 21, 2010, 11:34:44 PM »
Check the filiments they can blow easy,who needs lights anyway!
« Reply #14 on: June 21, 2010, 11:36:00 PM »
..the headlamp burns if i depress the "passing" button...
..tail-lamp burns bright when i squeeze the brake levers...
