Author Topic: Rear brake pads xciting 250  (Read 1455 times)
juancuesta
« on: January 12, 2017, 09:53:26 PM »
Hello, does anyone know how to replace the rear brake pads of the xciting 250? I have seen a ton of videos in the Internet , but I cant seem to get it right
The rear brake pads of my scooter do not have a pin , or screw that holds them in place , the only thing holding theme is a metalic piece on the bottom. Im unable to extract theme from there, how should I do this?
juancuesta
Re: Rear brake pads xciting 250
« Reply #1 on: January 14, 2017, 09:43:31 AM »
Finally I found out that you only need to push theme out with a screw driver, nothing holding them in place other than a small metalic plate on each side !
