Author Topic: Vibration in engine  (Read 3681 times)
laladownunder
Vibration in engine
« on: January 15, 2017, 01:40:28 AM »
My 50 cc Kymco Agility gy6 4t got 13,000 kilometer. Done all the upgrade de restriction mods and going fine for about 7,000 kilometers. On the way to work just started to vibrate, no vibration when idle, only when picking up revs, done whole exercise without belt and still vibrating, changed timing chain tensioner with new longer shaft tensioner. Still vibrating, sound seems to come from bottom on variator side of motor block. I opened tappid cover and turned engine over by hand to check timing chain for broken links, but none broken, still vibrating, Also put in new sliders in variator, still vibrating. I got new Timing Chain, guides, tensioner, complete gasket set. Need help/idea where to go next.
« Last Edit: January 15, 2017, 08:01:01 AM by laladownunder »
Mr. Paul
Re: Vibration in engine
« Reply #1 on: January 15, 2017, 01:48:45 AM »
Engine mount?
2009 Kymco People 150
1993 Honda Helix
laladownunder
« Reply #2 on: January 15, 2017, 04:46:25 AM »
Thanks Mr Paul, As solid as can come, vibration sound seems inside
« Last Edit: January 15, 2017, 12:04:56 PM by laladownunder »
laladownunder
« Reply #3 on: January 15, 2017, 08:02:34 AM »
Also removed the belt, which eliminate drag and rear end vibration ( if any ) Still vibrating when reving up
« Reply #4 on: January 15, 2017, 11:07:19 AM »
See if you can move crankshaft with CVT belt removed. That's up, down, fore and aft. Should be no movement.
laladownunder
« Reply #5 on: January 15, 2017, 11:48:37 AM »
Thanks Karl, done that and no up, down or sideways movement. also took the tappid cover of and started motor, oil everywhere, so oil pump working. Checked the timing chain again with the new longer timing chain tensioner and no extra movement on chain. touch the variator and immediately the cam moves.Also started motor with no variator disk and roller weights in, only the outside gear where starter pinion runs on, still vibrating.
« Last Edit: January 15, 2017, 11:51:49 AM by laladownunder »
ole two wheels
  • ole two wheels
« Reply #6 on: January 15, 2017, 07:09:57 PM »
Have you checked the spark plug.? A misfire can cause a shutter.  Is the vibration harmonic or erratic?
Also might try removing the valve cover and rotating the engine to make sure the valves are moving and not sticking. Hope you can isolate the problem.
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
« Reply #7 on: January 15, 2017, 08:25:29 PM »
Are there any missing blades on the variator fan? Also, please explain what you mean by "touch the variator and the cam moves."
tortoise
« Reply #8 on: January 15, 2017, 09:23:12 PM »
Include spark plug cap inspection in your troubleshooting.
ole two wheels
  • ole two wheels
« Reply #9 on: January 16, 2017, 02:06:25 AM »
Karl, wouldn't stuck sliders in the variator throw it out of balance?
Mac
Mac
2012 Kymco DT300
star667
« Reply #10 on: January 16, 2017, 03:23:52 AM »
Best way to find where the sound is, is to get a mechanics stethoscope and listen if you can't get one of those find the longest screwdriver you have put the metal end on the bike and the other end on your ear
Usually it goes like this
Deep internal rumble: Crank or big end bearings
Taping in the head: valves or tensioners or an exhaust leak
star667
« Reply #11 on: January 16, 2017, 03:25:00 AM »
After re reading your post I'd check the oil see if you can see any metal
« Reply #12 on: January 16, 2017, 01:34:33 PM »
Stuck sliders/rollers would do it, Mac, fer sure! Good point.
ole two wheels
  • ole two wheels
« Reply #13 on: January 16, 2017, 04:52:50 PM »
Yelp, the stethoscope will tell you where the noise is. You can get one from Harbor Freight Tools really cheap. Good idea. You will get "some" noise from any where on the motor, when it,s running, but it's the louder noises you are looking for. You will know when you hear them.  Good luck.
Mac
Mac
2012 Kymco DT300
laladownunder
« Reply #14 on: January 17, 2017, 12:27:37 PM »
Hi Mac, the vibration is harmonic and using a big screwdriver, seems noise is on variator side. I run engine without the internals of variator, no weights and pulley, just the outer pulley/ gear where starter motor kicks in for starting
