Did you miss your
activation email
Technical | How To
Vibration in engine
Pages:
Topic: Vibration in engine (Read 3680 times)
laladownunder
Newbie
Re: Vibration in engine
Reply #15 on:
January 17, 2017, 12:37:07 PM »
Hi Karl, I meant, that with the timing chain and new tensioner in place, if I turn the variator by hand there is instant movement on the cam. Checked the blades on variator and all the blades in place. I told a friend about what you said, move the crank up, down and sideways, He reacon that even that I could find no movement, it can still be the crank bearing in the block ( split casing in this case ) on variator side that worn away the bearing hole / seat just slightly now causing the outer race of bearing to actually turn in the casing. When idling, no vibration, when revving up it start vibrating. He even recon that there is maybe nothing wrong with the bearing, it just ate away the alum casing. What u recon
West Tennessee, USA
Reply #16 on:
January 17, 2017, 02:42:13 PM »
Sounds like it is time to completely dis-assemble the engine and inspect everything.
tortoise
Reply #17 on:
January 17, 2017, 07:24:20 PM »
Quote from: laladownunder on January 17, 2017, 12:37:07 PM
Unlikely . . crankshaft and connecting rod bearing failure is typical with 139QMB big-bore-kit installations, but somewhat rare for stock 50cc's.
star667
Newbie
Reply #18 on:
January 18, 2017, 10:45:28 PM »
Now this is coming from a older mechanic I am honestly not to familar with this scooter but the usual assumption if there is any vibration on the crank its a bad bearing knowing that don't run it anymore even if it is not it pays to be careful better that then paying for a new crank
laladownunder
Newbie
Reply #19 on:
January 20, 2017, 09:35:05 AM »
Thanks Tortoise, with no up down side way movement, I still think it to be the crank bearing, it just started and I have not driven it again, just fishing out to what might be the problem.
laladownunder
Newbie
Reply #20 on:
January 20, 2017, 09:36:39 AM »
Hi, thanks Karl, yup I am going to do it this weekend and hopefully it is only the bearing
laladownunder
Newbie
Reply #21 on:
January 20, 2017, 09:39:16 AM »
star667, I tend to agree with you and will strip it this weekend, Lucky I did not continue riding it when vibration started and hopefully it is just the roller bearing
laladownunder
Newbie
Reply #22 on:
January 20, 2017, 09:41:44 AM »
Thank you for everyone making an effort to help me. I think I am on the right track now and will not strip the engine for nothing, must be a bearing. Thanks
West Tennessee, USA
Reply #23 on:
January 20, 2017, 01:32:31 PM »
Don't take too long. I am holding my breath to find out what you find in that thing!
paceneedsstides
Cuz I can't drive...55!!...No I mean that I try...
Reply #24 on:
January 21, 2017, 02:29:41 AM »
I bet bad bearing
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
laladownunder
Newbie
Reply #25 on:
January 22, 2017, 09:40:56 AM »
Well, here we got it. It is the bearing on the variator side. Seems a bid of a grind - very softly - but enough for me to replace. Also there is ringmarks on outer racer indicating the bearing was turning in the seat/ hole. Will have to get a new crank as it seems like one hellofa job replasing bearing and will have to knurl the bearing seat/hole for a tap in fit - now both bearing slide in and out with hands only.
West Tennessee, USA
Reply #26 on:
January 22, 2017, 01:42:45 PM »
Don't forget about a Loctite product called "bearing mount" for just such an occasion as yours. I used it years ago on a SAAB transmission and it worked perfectly! Inside knurling is nearly impossible to find a shop that has the tooling. Need the whole crank just for the bearing? Gotta be some way to get that thing off.
Back
