Author Topic: 2014 mxu 450i 4wd button issue  (Read 1344 times)
hookset
« on: January 18, 2017, 09:32:00 PM »
This is a new machine, bought as a leftover this summer.  The 4wd button is finicky, when I push it I can hear the actuator working, etc, not binding or anything out of the norm, but when I let up the button doesn't always stay pushed in, which then disengages it.  If I keep pushing it multiple times, eventually it will stay engaged.  At first I thought it wasn't getting into 4wd, so I would roll forward a bit, etc. but it seems like it is all working, just the button wont' stay engaged.
Any advice before I haul it 75 miles to the dealer?
Bratman2
Re: 2014 mxu 450i 4wd button issue
« Reply #1 on: January 18, 2017, 11:35:13 PM »
I'll check my 2014 tomorrow. I have had no problem engaging 4whl drive. The dash has a display that shows when you are in 4whl drive. Are you sure it is disengaging?
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
hookset
« Reply #2 on: January 18, 2017, 11:58:28 PM »
I should have included that. The dash display cycles with the button. I think the button is this issue personally, but am not sure.
Bratman2
« Reply #3 on: January 20, 2017, 01:25:10 AM »
Sounds like you very well may have a button issue. Mine stays depressed until I push it again. Wonder if you could talk to the dealer and make sure they have a replacement switch first. So you go, they put new switch on, you leave. I know how you feel, I drove across state lines to buy mine. About a 140 mile drive. If was worth the price for me. My warranty is expired so anything comes up I'll just handle it myself.
2014 MXU 450i
2010 Grizzly 450
hookset
« Reply #4 on: January 20, 2017, 04:56:33 PM »
I talked to the dealer, they agree it's the switch most likely.
As soon as I am done ice fishing it will go down to the dealer to get fixed up.
