Author Topic: Lock disassembly?  (Read 1552 times)
eamartin
Lock disassembly?
« on: January 28, 2017, 01:15:50 PM »
Anyone have experience removing/replacing the key cylinder from a Kymco ignition switch lock?
Re: Lock disassembly?
« Reply #1 on: January 29, 2017, 09:55:17 PM »
My Kymco has a plastic screw on collar behind the panel.
Unplug the switch and replace.
Well, i have that backwards..
.the screw off collar is on the front of the panel.
Sorry, this was no help to you. Lock smiths can do more than we imagine at times. Agree with 'bolt's suggestion....go to their shop and give them a try.
« Last Edit: January 30, 2017, 02:42:24 AM by Stig »
eamartin
« Reply #2 on: January 30, 2017, 01:26:33 AM »
The key cylinder was removed from my bike.  I'm using a screw driver to turn on the ignition and to lock the fork.  I was just wondering if it's possible to install the key cylinder from another scooter into the housing (bolted to the steering head) of my bike.  All the various models seem to have different housings, but maybe the cylinders are interchangeable?
« Reply #3 on: January 30, 2017, 02:27:13 AM »
Try a locksmith.
souzamoto
« Reply #4 on: January 31, 2017, 05:14:34 AM »
Sounds Stolen
« Reply #5 on: January 31, 2017, 07:56:29 PM »
Sounds Stolen
Good point. This is not the first post like this.
My home town locksmith will need to see ID and registration or title, before working on a vehicles ignition switch.
eamartin
« Reply #6 on: January 31, 2017, 10:16:11 PM »
It might well have been stolen at some point.  I received a title for it when I purchased it.
« Reply #7 on: February 01, 2017, 01:12:27 AM »
You should have no problem then at your local lock smith. Cheaper if you take the scoot to him.
A good lock guy can do wonders for less than you'd imagine.
paceneedsstides
« Reply #8 on: February 01, 2017, 03:24:13 AM »
cheaper to just buy a new ignition and keyset from a Kymco dealer
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
eamartin
« Reply #9 on: February 05, 2017, 03:10:28 AM »
I bought the new one.
