Author Topic: KYMCO UXV 450i GROUND CLEARANCE...  (Read 2807 times)
jew8201
« on: January 30, 2017, 01:36:32 AM »
IN CASE YOU ALL DIDN"T KNOW, IT SUCKS!!!!! Got to get more clearance, especially on the front end. I was so aggravated with the clearance today. I put it through its paces and she always pulled through, but high centered a hand full of times. Got to fix this ASAP.
2015uxv450
Re: KYMCO UXV 450i GROUND CLEARANCE...
« Reply #1 on: January 31, 2017, 01:25:17 AM »
You can move the front shocks to the outer mounting position and crank them up a little.  My 450i went from 8" clearance in the front to 12". And has made no effect on ride quality
jew8201
« Reply #2 on: January 31, 2017, 02:18:33 PM »
Yeah I am planning to adjust my shocks on the preload. And I'm shopping 26" tires now. Relocating the shocks out will be my last resort.
airshot
« Reply #3 on: January 31, 2017, 09:58:46 PM »
    Havent had that issue yet, but then again I pay very close attention to what I am running over. With a machine slightly reduced in size you cannot expect it to go over objects taller than other machines will go. If you do your research most machines are around 10 in ground clearance so pick your path more wisely.
k9bitten
« Reply #4 on: February 07, 2017, 10:58:54 PM »
Why your last resort when it's the quickest and easiest step?
gotmyally
« Reply #5 on: February 08, 2017, 04:01:08 PM »
Do you have room to go bigger than 26"?  You'll only gain 1/2" in ground clearance going from the factory 25" tires to aftermarket 26" tires.
k9bitten
« Reply #6 on: February 08, 2017, 07:47:08 PM »
I went to 26 and relocated the shocks.  It made a world of difference. We ride mostly boulder strewn rocky trails. Here's a picture showing 26 on the left, 25 on the right and rear shocks in stock location.
« Last Edit: February 08, 2017, 07:49:14 PM by k9bitten »
jew8201
« Reply #7 on: February 09, 2017, 12:30:18 AM »
I have adjusted all of my shocks. Got the maxxis bighorn 2.0 ordered. the front tires (26x9-12) arrived yesterday. The rear tires (26x10-12-had to find this size on ebay as maxxis only makes the 26x10-12 bighorns for the john deere gators) should be here Monday. I can already tell it is sitting a little bit higher just from adjusting the shocks. I think I'll be in good shape with the new tires. These "25 inch" stock tires are no way an actual mounted height of 25" more like 23" IMO. The rear tires on my commercial JD zero turn are bigger than the stock tires on this thing and they are 24x12-12 tires.
k9bitten
« Reply #8 on: February 09, 2017, 02:14:59 AM »
You'll be good to go now.
jew8201
« Reply #9 on: February 09, 2017, 02:57:26 AM »
I hope so looking forward to seeing the tires on the machine. Noticed any difference in power or the power delivery?? How about top speed?
DG Rider
« Reply #10 on: February 13, 2017, 06:15:11 AM »
How are your skidplates holding up? They look kinda cheap and flimsy.
