Did you miss your
activation email
Technical | How To
Which springs are stiffer?
Topic: Which springs are stiffer? (Read 953 times)
thelastkahl
Newbie
June 21, 2010, 10:33:47 PM »
Is a 1500 spring stiffer than a 1000 spring? The spring in the picture on the left is the 1000rpm one and the one on the right is the 1500 rpm. The 1000 is about a 1/2 inch longer than the 1500. I would think that this would cause more pressure on the clutch and make a more effective engagement? I am confused???
http://cid-da80bd52d440bde2.photos.live.com/browse.aspx/Torque%20Springs
Last Edit: June 21, 2010, 10:35:47 PM by thelastkahl
undead primate
Re: Which springs are stiffer?
June 21, 2010, 10:39:02 PM »
..the 1500 is stiffer than a 1000, regardless of the lngth...
..the thickness and composition make a difference..
undead primate
June 21, 2010, 10:54:07 PM »
..with the stock head and piston, a 1000 in an A50 is about the limit...
Back
