Did you miss your
activation email
Offroad
Side By Side
Break Chatter UXV 450i
Topic: Break Chatter UXV 450i (Read 1014 times)
jew8201
Full Member
February 09, 2017, 12:50:52 AM »
When traveling forward, H or L doesn't matter, and applying medium to heavy brake pressure there is a chatter. Only does it when breaking. Is this normal??? Or a concern?? Thanks
DG Rider
Newbie
Re: Break Chatter UXV 450i
February 13, 2017, 06:16:47 AM »
Is the rear brake mounted on the driveshaft? If so, then its likely normal. My old Pioneer would make God-awful noises from that set-up.
February 13, 2017, 12:46:09 PM »
mine does on a steeper downhill grade
k9bitten
Jr. Member
Reply #3 on:
February 17, 2017, 07:40:27 PM »
Mine does it. Learned to ignore it. Seems to get a bit better with miles.
airshot
Reply #4 on:
February 18, 2017, 06:26:05 PM »
Mine is mostly in reverse and when the rear disc is very dirty. Sounds like hell but seems to be typical in shaft mounted disc brakes. If it get real annoying I just power flush the disc and pads with the garden hose and it goes away for awhile....but it does come back when it gets dirty again
Back
