Author Topic: I press electric start and nothing happens no click or nothing?  (Read 756 times)
Georgelock
« on: February 12, 2017, 03:12:31 PM »
Recently I've had a problem with my electric start where when I try to start it via electric start nothing happens no noise or nothing, but it kicks over first time still? Is this an electrical fault or something with the starter motor?
Mr. Paul
Re: I press electric start and nothing happens no click or nothing?
« Reply #1 on: February 12, 2017, 08:59:04 PM »
I know its obvious George, but have you tested the battery? When you turn the key are your running lights as bright as normal?
2009 Kymco People 150
1993 Honda Helix
ole two wheels
  • ole two wheels
« Reply #2 on: February 13, 2017, 01:58:09 AM »
Check the small wire that's attached to the solenoid from the ignition switch. If it is off then your key switch isn't telling the solenoid switch to close. If the wire is on, then back up to the starter relay. If the relay is okay, follow Mr. Paul's suggestion. Or try this in reverse order.
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
