Author Topic: Another Busted Belt after 4K miles  (Read 3181 times)
RubenC
« on: February 12, 2017, 06:31:52 PM »
Hi Everyone
Just over 2 weeks ago and just over 4k since my last belt broke, my 2012 Dowtown 300i belt broke again.  I don't know why this happening any suggestions.  Beside get a new scooter.  This time, I was using Dr. Pulley's sliders.
Ruben
From the Great Nation called Texas. Oops I mean the Great State called Texas
Re: Another Busted Belt after 4K miles
« Reply #1 on: February 12, 2017, 10:45:30 PM »
4k miles too soon based on experience of several riders on this forum. 20000 to 40000 miles and belt is still good seems normal for the DT300i. What weight of sliders and how do you ride the bike?
« Reply #2 on: February 12, 2017, 11:25:51 PM »
when the belt go,s that fast ,.  the pulleys could be off set, missing washers ( shims )  just take the cover off and look at belt with motor running
Mr. Paul
« Reply #3 on: February 12, 2017, 11:47:41 PM »
(This is a biggie) Did you buy a Kymco OEM belt? If not, that is your problem. Otherwise;
 Do you rev the scooter at traffic lights? Is the scooter idle set high? Do you ride two-up a lot with hills? Do you accelerate/decelerate rapidly? Sounds like something is causing too much heat in your cvt system. I would try to rule out riding style and conditions and work from there. Best of luck!
2009 Kymco People 150
1993 Honda Helix
kneeslider
« Reply #4 on: February 13, 2017, 03:54:14 AM »
I think the issue is that the belt would not be original, hence the wrong specifications.
2019 Yamaha X-Max 250
Mr. Paul
« Reply #5 on: February 13, 2017, 10:44:04 AM »
I suspect the same Kneeslider. Many after-market belts are not the same quality/size as the original.
1993 Honda Helix
Snorvey
« Reply #6 on: February 13, 2017, 01:41:50 PM »
I'm guessing that a belt snap isn't as catastrophic as a chain snap on a normal motorcycle?
I had a chain snap on my RD250LC once - it took half the crankcase cover away, the entire chainguard and gouged the swinging arm. It also wrecked the back tyre as it locked up, leaving monsterous skidmarks on both the road surface and my underpants.
RubenC
« Reply #7 on: February 14, 2017, 12:40:12 AM »
Kymco Belt
« Reply #8 on: February 14, 2017, 12:58:35 AM »
Kymco Belt
Wrong size KYMCO belt? You probably know it's correct, so, you are right. Something seems quite wrong.
CVT assembled correctly ?....front/back belt pulleys misaligned? ....the shims, washers, etc. in correct position or missing?
Airducts open on CVT cover for proper airflow ?
Riding at max speed for long periods with 2-up......if not - what else could cause belts to break so often?
Old/rotten/aged belt ?
HEAT, misaligned parts (incl. weights), gouged pulley surfaces, roller/slider weights too far away from stock size.
I got nothing else.
Please let us know what you find.
Mr. Paul
« Reply #9 on: February 14, 2017, 01:41:19 AM »
This ones a head-scratcher for sure Ruben! Let us know please.
1993 Honda Helix
« Reply #10 on: February 14, 2017, 01:49:04 AM »
  number 1 belt came with scooter,   1009/ 24    30 degree,.
 # 2 belt 1004 / 24.5    30 degree
 # 3 belt  1004 / 24.3   30 degree
 # 4 belt 1004 / 24.1   30 degree
    all kymco belts made by mitsuboshi,.      mitsuboshi spec.  1004 / 25.5    30 degree,   seen that on a spec. sheet from mitsuboshi,  never could find it again,
RubenC
« Reply #11 on: February 14, 2017, 03:43:17 AM »
 I am waiting to hear from Moxie's Scooters as to why this has happened.
RubenC
« Reply #12 on: February 16, 2017, 08:33:10 PM »
According to John @ Moxie's Scooter, the variator wore out that is what casued the belt to break.
« Reply #13 on: February 16, 2017, 08:58:21 PM »
How many total miles on the bike?
Mr. Paul
« Reply #14 on: February 16, 2017, 09:20:55 PM »
Thanks for the update Ruben! I am glad you found the problem. :)
1993 Honda Helix
