Author Topic: Let's try this  (Read 1754 times)
LidoCA
  • I LIKE chinese plastic.
Let's try this
« on: February 14, 2017, 01:28:42 AM »
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
LidoCA
Re: Let's try this
« Reply #1 on: February 14, 2017, 01:36:32 AM »
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
TroutBum
  • 2012 Like 200i (sold)
Re: Let's try this
« Reply #2 on: February 14, 2017, 08:51:48 PM »
Nice and shiny. Why did you have it apart? Any problems with the plastic tabs? They make me nervous when I encounter them. I feel like they will snap.
Re: Let's try this
« Reply #3 on: February 14, 2017, 09:25:31 PM »
Nice job! Photobucket stopped working for me even after Stig helped me.
LidoCA
Re: Let's try this
« Reply #4 on: February 14, 2017, 11:42:56 PM »
 One of the bolts broke for the air box mount. I Drilled the bolt and tried an easy out extractor. The easy out broke off inside the bolt. I could not get a good center in the hole to drill it again. My solution was to remove the rear wheel and drill out the bolt from the back side. Retapped the hole. Actually, the new threads were not very deep, due to damage from my drilling from the front. I installed a longer bolt and added a lock nut to the inside. Double security with lock tite.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
Re: Let's try this
« Reply #5 on: February 15, 2017, 01:34:11 AM »
Great job....and Great pictures there Lido!
But, for Pete's Sake.....this is a family forum - put some pants on that scooter!!
PS: How do you like your City Grips - this summer will probably replace my rear C.G. with @12,000 miles on it. Front still looks good.
And PPS: Did I miss your review of your S-Max? Please tell us about it....with pix - if it won't make you crazy! :)
« Last Edit: February 15, 2017, 01:46:11 AM by Stig »
LidoCA
Re: Let's try this
« Reply #6 on: February 15, 2017, 02:12:45 PM »
Notice the cover is raised on the other scooter. I needed to look at it to see how things go back together. I needed to check the tire hugger set up before reinstalling.
« Last Edit: February 15, 2017, 02:16:28 PM by LidoCA »
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
Re: Let's try this
« Reply #7 on: February 15, 2017, 11:22:15 PM »
Steve, the bolt for the airbox mount broke ?
Or was it over-tightened, or found to be seized upon removal?
I have found some screws and nuts on scooters and motorcycles which are so darn tight that I'm concerned about breaking the tool (allen wrench for ex.) or shearing off the hardware trying to loosen them for the 1st time.
I never use a torque wrench on smaller nuts. Have more trust my bare hands than a less-than-expensive, not freq. re-calibrated torque wrench.
Great pictures of your LIKE200i ! Looks like you take good care of them both!
LidoCA
Re: Let's try this
« Reply #8 on: February 16, 2017, 03:57:08 AM »
 After a long ride after Christmas, I found the bolt broken off. The air box was bouncing around on one bolt and broke the front mount. I repaired the plastic air box with some epoxy. So far it is holding up. The tire hugger brackets were broken as well from the long rough ride. The Like ran for hours on rough roads at high speeds. I cruised 90 miles to Ventura on that very windy day.
 I took the tire hugger mounts from the back up Like. I will order new ones after I see if the air box repairs hold up. I can combine shipping that way.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
LidoCA
Re: Let's try this
« Reply #9 on: February 16, 2017, 04:25:17 AM »
MG]http://i68.tinypic.com/wvrc53.jpg[/IMG]
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
