Author Topic: Agility 50 de-restricting problem  (Read 3197 times)
necapk
« on: June 24, 2010, 08:32:56 PM »
Hello!
I have a 2005 Kymco Agility 50.
My top speed is 50 kmph.
I tried everything I found on internet, but my top speed is still the same.
Please help me...
Re: Agility 50 de-restricting problem
« Reply #1 on: June 24, 2010, 09:11:43 PM »
..okay, what have you done so far??
peace
necapk
« Reply #2 on: June 24, 2010, 09:26:49 PM »
carb, air and fuel injection into the engine (sorry, I dont know how to explain)
That's everything I can find
« Reply #3 on: June 24, 2010, 09:28:23 PM »
..have you removed the bushing from the variator//
..have you de-restricted your cdi??
necapk
« Reply #4 on: June 24, 2010, 09:30:05 PM »
I didn't tried that
I was too scared to cut the CDI...
« Reply #5 on: June 24, 2010, 09:32:07 PM »
..you MUST do those mods...
..should have done them first...
..the cdi thing is easy, and as long as you cut as instructed, there is no danger of hurting it...
..there is nothing below the area that you make the cut...
necapk
« Reply #6 on: June 24, 2010, 09:33:18 PM »
and, how to de-restrict variator?
« Reply #7 on: June 24, 2010, 09:41:55 PM »
..here is a pic of my cdi..
..it's cut so severely to show that there is nothing there to harm...
..don't do your's like this tho!!
necapk
« Reply #8 on: June 24, 2010, 09:51:14 PM »
I will try tomorow to do these things
My top speed at the moment is 50 kmph.
When I finish all the work....my top speed will be???....your prediction...
« Reply #9 on: June 24, 2010, 09:56:11 PM »
..Basic instructions for replacing the boss drive: 1-Remove bolts(8mm socket) from the cvt cover  2-Remove hex nut (17mm socket) from crankshaft 3-Remove outer half of drive pulley(drive pulley face)  4-Remove drive belt from shaft  5-With left your hand, hold inner half of pulley(movable drive face),and with your right hand remove the boss face drive(variator spacer). Be sure that you hold the inner pulley half securely to insure that the roller weights remain in their proper position (they could fall out)  6-Insert new drive boss  7-Install belt  8-Install Pulley half and hex nut..(add a bit of blue Lock-Tite)  9-Install cover...
..enjoy the increase in performance!!!
..if you've installed a free-flow air filter, you also need to increase the size of the main jet in your carburetor..
..with these mods, you should easily get up to 70+ kmh..
necapk
« Reply #10 on: June 24, 2010, 10:02:45 PM »
Thank you very much!!!  :)
« Reply #11 on: June 24, 2010, 10:09:17 PM »
..google youtube for some vids on changing out that boss..
..there's a bunch of them out there...
..and you're quite welcome!!
peace
glopezz05
« Reply #12 on: July 24, 2010, 05:06:46 PM »
been looking for the variator boss drive videos you mentioned.  So far no luck.
Im usually on a bicycle, so for me, this thing is hauling ass!
jay20
« Reply #13 on: July 27, 2010, 07:12:05 PM »
i have a kymco agility 50 2006 4 stroke what can i do to derestrict it i have been told by a shop that doin the cdi wont make a difference to my scooter will it?
glopezz05
« Reply #14 on: July 27, 2010, 07:28:02 PM »
Unless you already have a derestricted cdi I think it will. I noticed in a big way, much higher top speed. And on the hills that I'm surrounded by, it's a big help.
