Author Topic: Kymco body parts  (Read 972 times)
poppajim
Kymco body parts
« on: March 10, 2017, 02:42:35 AM »
Where is the best place to buy kymco replacement oem body parts? I have a 2012 kymco gt300i and all the bolts that hold the trunk on snapped while taking it off. I wanted to put the original truck back on. I will try to drill them out but was wondering if there was such a place?
poppajim
paceneedsstides
Re: Kymco body parts
« Reply #1 on: March 10, 2017, 04:57:13 AM »
www.kymcopartsmonster.com is where I got some for my 2013 Like last yr
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
Tromper
  • Seattlish
« Reply #2 on: March 10, 2017, 08:36:04 AM »
Same for my 09 S 200.  No problems, even had the the correct color.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
Valy
« Reply #3 on: March 10, 2017, 09:11:42 AM »
Hi
You can also ask here:
http://atvscooterparts.com/content/category/2-kymco-models
Kymco oem parts.
poppajim
« Reply #4 on: March 11, 2017, 03:17:32 AM »
Thanks for all of your replies, i will try drilling this weekend. I am pretty sure I can get the job done. If not between this post and a earlier post by  TroutBum I am sure I will find the part needed. Thats why this forum is so great always somebody to help you out.
Ride Safe
Still cold and snowy here is Northern NJ.
poppajim
« Reply #5 on: March 14, 2017, 05:59:41 PM »
no success in drilling ordered today from Kymcomonster.com. Thanks for that info, very pleasant in the ordering process. Around 20inches of snow on the ground here in Northwest NJ so far. Looks like it is winding down hard to tell with the wind. Hope all are safe and sound.
ole two wheels
  • ole two wheels
« Reply #6 on: March 15, 2017, 01:39:14 AM »
You might try using a left hand drill or if you can't find one then try an "easy out." Or as a last resort drill the entire bolt using a slightly over sized bit and then tap the holes out to the next size up, metric or ASE. If the nuts are molded in plastic don't get it too hot. Have a wet rag to cool it. Hope this helps.
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
