Author Topic: need a stronger spring for rear suspension  (Read 840 times)
forkintheroad
« on: March 10, 2017, 07:20:48 PM »
Any recommendations? I'm a heavy rider. I just want a less mushy suspension. Seems like an easy replacement but I'm not sure if there's a recommended spring anyone has used.
Mr. Paul
Re: need a stronger spring for rear suspension
« Reply #1 on: March 11, 2017, 12:11:46 AM »
Hello there. Did you know you can adjust the existing rear spring to make it stiffer and less mushy? If you havent here is a link that explains how to do it. It is for a Piaggio but they are all basically the same. Hope that helps.
http://modernvespa.com/forum/wiki-proper-way-to-adjust-shock-preload
« Last Edit: March 11, 2017, 12:21:40 AM by Mr. Paul »
2009 Kymco People 150
1993 Honda Helix
forkintheroad
« Reply #2 on: March 14, 2017, 02:34:56 PM »
Thanks. I'm going to do that.
Mr. Paul
« Reply #3 on: March 14, 2017, 09:00:04 PM »
Great Fork! I believe that will fix your problem, and its easy and free! Please let us know if it works out.
1993 Honda Helix
Redk
« Reply #4 on: April 30, 2017, 03:15:39 PM »
IMO
This is an indication you should probably use this scooter for low speed, handy type use, near to home, for short trips at lower speeds.
If you do need a scooter with more weight capacity it might be best to get a larger one designed for a heavier rider.
redk
