Author Topic: LIKE200i rear wheel removal #2  (Read 22975 times)
Re: LIKE200i rear wheel removal #2
« Reply #15 on: May 14, 2020, 01:49:04 PM »
Do all the Kymco Likes have dual rear suspension? The through axle would make a trailer hitch easier than on the Agility.
Don't know about the 2nd gen LIKE150i's , but the 1st gen LIKE's are the same as this.
Major Tom
« Reply #16 on: September 16, 2020, 05:16:45 PM »
As said last time there was some wait for spareparts, which l got incredibely fast acounting italian mode.
Well, just for you maybe to compare prices over here.
I bought;
-1 brake disc BREMBO INOX €50,-
-1 set of brake pads ital brand €27,-
-1 bearing FAG 6203 C 2 HRS €11,-
-1 tire GOODRIDE  €27,-
it took me today from 1000 until 1500 hrs
inclusice a bycicle ride to a tire shop to change
balancing and disposal of old to new for €15,-
Disasambling went thanks to Stigs pics pretty fast and without any complications.
Heat and freeze method to get the bearing out and in again worked like a charm, heating for a while with a heatgun, then a light tap with a piece of wood and small hammer, out it fell the old one, which was not bad at all but, would be weird not to change it now.
Meantime, the bearing froze, l heated on and on, went for the bearing and just let it drop in.
Snapring in again, cool down by itself.
TBC
« Reply #17 on: September 16, 2020, 05:28:13 PM »
Rear brake, tire, bearing 2
BREMBO disc fitted 100 % what l expected from this brand.
Since l had her already in the workshop l enlarged the sidestand pad a little bit, 'cause sometimes when l parked at soft ground it sank  and nearly dropped.
My test ride after this entertaining morning and half afternoon brought me to Grado where l had to take gelato. All well, running without any trouble.
Regards from Italy, Ruffus
« Reply #18 on: September 16, 2020, 06:52:55 PM »
Nice job Ruffus!
Thanks for sharing your experience!
« Reply #19 on: September 17, 2020, 07:12:44 AM »
Good days work. Nice job Ruffus.
