Did you miss your
activation email
Scooters - 125 to 300
People 250
replacement mirrors
Topic: replacement mirrors (Read 2283 times)
ispud
Sr. Member
replacement mirrors
June 25, 2010, 05:15:35 PM »
Finally got around to removing mirrors to look at the possibility of extending the stalk so I could see behind me - I did it on my Aprilia and it worked marvelous. I can't get the mirror off the stalk - not sure how it is attached, so I am going to see if maybe I can find new mirrors that stick out further. Any ideas? On my Aprilia I added a 3 inch bolt to the end by welding a metric nut on the head of the bolt - hopefully this summer I will make some new ones out of S/S round rod - on the Aprilia the mirrors are threaded on the end.
No charge to reply.
undead primate
Re: replacement mirrors
June 25, 2010, 10:24:41 PM »
..ispud, can you post a pic of what you're looking at??
..the mirrors on my ppl 50 look like there's a "compression" type nut where the mirror body is attached to the stalk..
..dunno if your's is different or not...
peace
Last Edit: June 25, 2010, 11:10:13 PM by wordslinger
ispud
Sr. Member
June 26, 2010, 10:17:45 PM »
I make two aluminum flat bar extensions that raise the mirrors one inch and move them out 3 inches - very happy with the outcome.
To try to answer your question - the round shaft goes up to a seam that has a plastic trumpeting shaped sticking out that the mirror rotates in. In this seam there are 2 round indentations - possibly a place to get a hold with a spanner wrench - I screwed with this some and then decided to go to the flat bars - will post a picture Monday at work.
undead primate
Reply #3 on:
July 01, 2010, 10:50:36 PM »
...cool..i can picture it in my mind...
..kind-sorta....
olbull
Full Member
Reply #4 on:
July 02, 2010, 01:58:55 PM »
http://www.dr650mirrorextensions.com/
I have 3+ extensions on my bike...How do I post a pic here???I will take a few and show you
2007 P250
If your not the lead dog the scenery never changes
ispud
Sr. Member
Reply #5 on:
July 07, 2010, 05:18:08 PM »
a photo
ispud
Sr. Member
Reply #6 on:
July 09, 2010, 07:29:50 PM »
sorrry - not the best, but gives a good idea of concept - works great.
undead primate
Reply #7 on:
July 09, 2010, 10:07:16 PM »
...yeahhh...is that your mirror's base on top of the flat?
...don't look like mine...
ispud
Sr. Member
Reply #8 on:
July 19, 2010, 07:43:29 PM »
mirror is bolted on from the bottom - it is on top of flatbar.
Back
