Author Topic: Seat removal  (Read 2574 times)
docjones
Seat removal
« on: June 25, 2010, 07:35:20 PM »
I want to take my seat along with the tub underneath off to examine all the lines in and out of the carb. I've read many different accounts of this from the one phillips screw under hinge and the two bolts next to the trunk latch to all six nut and bolts under the seat. Any one know the easiest or proper way to do it.
09 Agility 125
Lammy1000
Re: Seat removal
« Reply #1 on: June 25, 2010, 08:13:37 PM »
Go to you tube and search for various maintainence procedures.
marioG
Re: Seat removal
« Reply #2 on: June 26, 2010, 05:42:27 AM »
2screws, 6 x 10mm bolts....
then pop it up....
FUBAR is an acronym that commonly means "f***ed up beyond all recognition/any repair".
dwnthehatch
Re: Seat removal
« Reply #3 on: June 26, 2010, 06:58:47 PM »
4 10mm bolts and 1 phillips screw. I just had mine off to wire in a brake moduator. The seat bucket is larger than the opening. You have to gently seperate the plastic panels to get it all of the way out.
docjones
Re: Seat removal
« Reply #4 on: June 28, 2010, 03:19:17 PM »
Thanks all. It was the last answer inthis post. 4 bolts and 1 phillips head screw. It took some effort to pull it out and somemore to reinstall it but now I know how it is done.
09 Agility 125
jprestonian
    • a scooter called wanda
Re: Seat removal
« Reply #5 on: June 28, 2010, 04:33:25 PM »
Yeah -- removing the seat from the bucket doesn't get you a whole lot.  ;)
At the shop, we have a set of t-handled wrenches for removing seat buckets. They're about 16" long, and perfect for the job. Harbor Freight probably carries them (as the shop owner is a HF junkie).
