Author Topic: SURFACE RUST STARTING!  (Read 1464 times)
Nireen
« on: March 27, 2017, 08:08:39 AM »
Any suggestions friends.  I am starting to get a little surface rust on the wheel plates.  What to do now before things get serious??
Kat :)
Tromper
  • Seattlish
Re: SURFACE RUST STARTING!
« Reply #1 on: March 27, 2017, 09:50:14 AM »
Wheel plate?
I r an ignant git.
Do you mean the brake rotor, the actual rim or ?
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
Nireen
« Reply #2 on: March 27, 2017, 10:11:49 AM »
Yes the brake part. :)
Kat :)
Nireen
« Reply #3 on: March 27, 2017, 10:12:24 AM »
Or wheel plate I guess. :P
Kat :)
Nireen
« Reply #4 on: March 27, 2017, 10:15:36 AM »
Gosh bike is dirty.  That is what ya get when you ride in the winter months here in Canada. :P Did not get to clean it up the last run.  I usually clean it after a ride when it is warm enough.
Kat :)
Tromper
  • Seattlish
« Reply #5 on: March 27, 2017, 11:33:28 AM »
I wouldn't worry about that too much; although washing the salt off is a good idea.
If you're feeling ambitious in the summer you can take it apart, sand it a bit and paint it, or just order a new one.
Rotors wear out before they rust though normally and a little rust like that is far from unheard of.
Doesn't hurt to keep an eye on it though, & I wouldn't leave it sitting soaked in road salt if I could avoid it.
You may want get underneath the plastic and give the bike a once over too. If the frame is getting a bit of rust I would address that, if your exhaust is I'd hit that as well.
I'm not familiar with the foibles of the downtown but it's not uncommon for a vehicle to have a spot where the damp and salt like to sit.
If you're aware of it and check it now and again, maybe clean it and give it a spot of paint no big.
Normally no big, but it can, in extremis, weaken the frame at a weld, or a bare spot potentially.
Nireen
« Reply #6 on: March 27, 2017, 11:37:28 AM »
Tromper, with the rust on frame or muffler what would you use or do?  What about spraying the muffler with that muffler paint?
Kat :)
Nireen
« Reply #7 on: March 27, 2017, 11:38:22 AM »
Thank YOU very much for your support here :)
Kat :)
« Reply #8 on: March 27, 2017, 03:58:55 PM »
   Salt prevention ,  turn into a snow bird,.  Palm spring comes to mind,
ole two wheels
  • ole two wheels
« Reply #9 on: March 27, 2017, 04:00:02 PM »
So I can call you Kat, Great. Remove surface rust from Chrome wilh an SOS pad and plenty of water. Rub lightly and then dry and apply chrome polish. Painted surfaces, use a small "detail" wire brush with soft wire and brush lightly, followed with either spray paint or coat with WD-40. Next question?
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
beermak
« Reply #10 on: March 27, 2017, 04:08:01 PM »
I would worry more on the pads.. they seem not to be in full contact with the disc.
Enviado desde mi iPhone utilizando Tapatalk
Nireen
« Reply #11 on: March 27, 2017, 05:21:20 PM »
:D You inviting me!! :D
Mac
Kat :)
Nireen
« Reply #12 on: March 27, 2017, 05:22:18 PM »
How can you tell this?
Kat :)
Nireen
« Reply #13 on: March 27, 2017, 07:40:20 PM »
:D So is this invitation :D
Kat :)
« Reply #14 on: March 27, 2017, 09:52:16 PM »
  Wish I could go south my-self,      649 I hope !  or cash for life, would do it,.
