Author Topic: go up hill bottom out  (Read 1850 times)
hieumait
« on: March 29, 2017, 11:49:47 PM »
new carb, plug, unrestrict flat road super 9 lc can 30-40 miles easily rpm around 8-9k, when go up hill bottom out rpm max out 10k, barely go up around 20mph max cant go any faster any suggestion? engine code SH10DA
chaz35
  • old guy
Re: go up hill bottom out
« Reply #1 on: March 30, 2017, 03:03:18 PM »
hieumait, how much you weigh?, your S9 LC is not running well.  Please clarify, are you saying you are turning 10,000 rpms and only going 20mph?
paceneedsstides
« Reply #2 on: March 30, 2017, 05:45:22 PM »
rpms shoul actually be less going uphill but the best thing for sustained uphill speed is performance variator with heavier weights and stiffer rear toqque spring.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
hieumait
« Reply #3 on: March 31, 2017, 10:23:05 AM »
I only weight 125lbs, go up hill it bottom out rpm seem be max 10k and barely, but flat road seem be fine, what roller weight,  variator, spring should  I use ?
chaz35
  • old guy
« Reply #4 on: March 31, 2017, 01:57:03 PM »
why did you install new carb?, tell us about the carb.  Cheers
hieumait
« Reply #5 on: March 31, 2017, 09:44:31 PM »
AUTO BYSTARTER SET screws broken off try to drilled then out end up fck the carb lol, replace complet CARBURETOR ASSY from http://www.kymcopartsmonster.com....strange flat seem be fine ... up hill struggle, should I put original roller weight (8gram) instead of 3gram & 6 gram stack?
« Last Edit: March 31, 2017, 09:47:33 PM by hieumait »
chaz35
  • old guy
« Reply #6 on: April 01, 2017, 01:41:24 AM »
OK, I understand carb, you can bypass auto bystarter if you want, but will have to manually choke carb to start.
Why did you install 3gr and 6gr rollers?  How did it run with stock 8gr?  At your weight 125#, probably don't need really light weight rollers to get acceleration.  When rollers are too light, trad-off is often less top speed.  Engine peak torque is where you get max acceleration, speed up hill, with stock exhaust pipe peak torque is approx 7000 revs, less or more revs, engine is not working at maximum.  Good luck...
hieumait
« Reply #7 on: April 01, 2017, 08:45:34 AM »
I got the moped free, and it come 3gr & 6gr roller weight on it, I believe it have been modify, it has Tecnigas exhaust on it, soo should put back 8gr roller weight?, how does it effect speed and torque while on flat road vs uphill, thank
Mr. Paul
« Reply #8 on: April 01, 2017, 11:53:03 AM »
Go with the stock weights. It may "feel" like it accelerates better with lighter weights but all likelihood it is not going to outperform the stock weights. In my experience, the Kymco engineers knew what they were doing when they designed these machines! The lighter weights do not allow your engine to get into its torque band because the rpms are too high.
2009 Kymco People 150
1993 Honda Helix
paceneedsstides
« Reply #9 on: April 01, 2017, 05:18:34 PM »
shouldn't lighter weights allow variator to pop out sooner but not as far so faster to a certain rpm range but lower rpms in general heavier weights slower on get go but further travel and higher top speed hence higher rpms?
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
« Reply #10 on: April 01, 2017, 05:20:01 PM »
unless maybe his rear puller is stock open and not closing or clutch slipping?
94 main jet
Malossi Multivar
Stage 6 upgear kit
Mr. Paul
« Reply #11 on: April 01, 2017, 05:46:35 PM »
Hey Pace! I have found that heavier weights than stock do affect acceleration and even affect top end because of the extra inertia required to turn them decreases rpm. Stock weights are not "heavy." They are usually just right. I have done tests of different weights and timed the real speed over distance. The lighter weights did give a PERCEPTION of faster acceleration, but the data just did not prove that out. I was not accelerating faster, it just sounded like it. :)
1993 Honda Helix
paceneedsstides
« Reply #12 on: April 01, 2017, 05:57:46 PM »
I've never noticed less acceleration that stock with heavier weights the like had 8.5g stock when I wrnt to the Malossi Multivar they came with 9G rollers and I definitely noticed a differance witht hem in top speed then went to 6gr and back to 8gr Dr Pulley sliders once had BBK and upgear kit on to keep it around 9600 rpm tops which on my LIke 50 was 65mph
94 main jet
Malossi Multivar
Stage 6 upgear kit
