Author Topic: CDI location???  (Read 1162 times)
My_Lil_Kymco
CDI location???
« on: April 03, 2017, 03:10:02 PM »
Please call me stooped if necessary but I'm looking in the battery compartment for the CDI, but there is only the relay and main fuse, anyone can call me dumb and tell m where it is?
Kymco super 9 ac
Tanks
My_Lil_Kymco
Re: CDI location???
« Reply #1 on: April 03, 2017, 04:07:53 PM »
Is it mounted on the frame, marked "Kymco D406" ???
paceneedsstides
Re: CDI location???
« Reply #2 on: April 03, 2017, 05:41:49 PM »
black rectangle and plastic that should be it but you don't gotta worry bout cdi worry bout getting a new BBK and jetting you carb right
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
My_Lil_Kymco
Re: CDI location???
« Reply #3 on: April 03, 2017, 06:44:55 PM »
Wanted to confirm it's working and not at fault as I'm checking the whole ignition system as I can't adjust the timing.
I think my idle jet is still low, is there a formula or anyone have a 70cc malossi on a 14mm carb as reference for jet sizes
paceneedsstides
Re: CDI location???
« Reply #4 on: April 04, 2017, 04:30:51 AM »
do you have stock pipe and CVT stuff?
94 main jet
Malossi Multivar
Stage 6 upgear kit
My_Lil_Kymco
Re: CDI location???
« Reply #5 on: April 04, 2017, 01:48:08 PM »
No, it's vince what's his face and the cvt rollers at 6gms I think, 70cc malossi block and head.
My_Lil_Kymco
Re: CDI location???
« Reply #6 on: April 04, 2017, 02:58:29 PM »
Will write full report soon as possible as I am just about to eat dinner
paceneedsstides
Re: CDI location???
« Reply #7 on: April 04, 2017, 04:13:54 PM »
Leo Vince Handmade ZX I'm assuming with that setup you should definitely work on upjetting big time and or getting a bigger carb also have to play with roller weights to stay in the right RPM range
94 main jet
Malossi Multivar
Stage 6 upgear kit
My_Lil_Kymco
Re: CDI location???
« Reply #8 on: April 05, 2017, 09:32:56 AM »
Yes, Leo vince zx, exactly!
I put rollers in that came with the exhaust.
As supplier didn't have jets, to get me outa trouble I drilled out main jet to 1mm, allowing for wobble I'd say it's 1.1m min. The idle jet is still standard.
I did order jets from uk but never arrived!
Will reorder again and keep fingers crossed.
Sorry pace, I didn't write full info last night, had a call out on a fault I had to attend.
But I see your on the 49cc forum and the Kymco too and see your replies on both.
In the 49cc I'm sure you saw my previous posts when it started to soft seize and I rebuilt engine before, well there is all the back story.
Rev range, since I changed rollers it improved dramatically, until the recent event lol.
I plan to get new piston etc thurs/Friday.
And rebuild it Friday evening.
Have to sit with current drilled out main jet and standard idle till the new jets arrive from the uk.
What carb would you recommend, or what jet sizes?
Thanks for your help
paceneedsstides
Re: CDI location???
« Reply #9 on: April 08, 2017, 06:33:06 AM »
I would hget 19mm Dellorto carb or 19mm carb that has alot of parts out there it's easy for me to find parts for Dellortos so thats what I use on an open filter and exhaust on same performance scale as yours I was running 92-96 jet depending on temperature a CHT really helps oyu to tell when you're jetted right as it tell you head temp at WOT
94 main jet
Malossi Multivar
Stage 6 upgear kit
My_Lil_Kymco
Re: CDI location???
« Reply #10 on: April 10, 2017, 01:02:54 PM »
I will look into it when I go get piston, will update you when I been.
My_Lil_Kymco
Re: CDI location???
« Reply #11 on: April 16, 2017, 06:17:54 PM »
Hi, ok I got piston, installed and it's running again, starts on the button.
I have a 19mm carb on order from the uk, 2000miles away lol
paceneedsstides
Re: CDI location???
« Reply #12 on: April 17, 2017, 05:20:35 PM »
where are you located I can give you vendors alot closer if in US or Canada?
94 main jet
Malossi Multivar
Stage 6 upgear kit
