Author Topic: Please, How do I pull the pads out now? See my attached picture.  (Read 804 times)
Nireen
Hi I got the first part of the back brake off but how do I now pull those pads out?  Also any suggestions on cleaning it?  I did take a wired brush to some of it.
« Last Edit: April 03, 2017, 10:12:47 PM by Nireen »
Kat :)
Re: Please, How do I pull the pads out now? See my attached picture.
« Reply #1 on: April 03, 2017, 11:45:11 PM »
  that hex bolt to the left comes out, that is the pin the pads slide on
Nireen
« Reply #2 on: April 04, 2017, 09:56:32 AM »
OK and yeah I just realized I need to actually remove both of those bolts...
Kat :)
Nireen
« Reply #3 on: April 04, 2017, 10:55:02 AM »
I may have to do as the book says and remove the dang muffler.  There is no way I can get a tool in there to remove that left bolt especially. :P
Kat :)
Redk
« Reply #4 on: April 24, 2017, 10:42:31 AM »
IMO, brakes on a machine are among those things you should have an experienced person oversee, for your learning experience.
redk
« Reply #5 on: April 24, 2017, 12:44:15 PM »
That's what we are for, Red!
Nireen
« Reply #6 on: April 24, 2017, 04:37:38 PM »
What are you so afraid of? :) Come up for air would ya :D I mean this in all goodness...
redk
Kat :)
« Reply #7 on: April 24, 2017, 05:07:18 PM »
  The brake pads will need to be pryed out ,  I take the calipers off , to clean every thing,.  so the lower two bolts in the picture off,.   then lift off,  the disc,.  turn it around to see the other side you will see how it is held in there,
Nireen
« Reply #8 on: April 24, 2017, 05:37:05 PM »
Yeah I got all the way until it was time to actually pry the pads out. I just wanted to have a real good look at the wear and for the practice of doing this! :)
Kat :)
