Author Topic: Speed Update (78MPH) Kymco Puig (Pics)  (Read 1246 times)
scorion57
« on: April 05, 2017, 04:06:04 PM »
Flat road heading west, North wind 10Mph.. topped out at 78.
FYI: if you order the windscreen from Kymco for the People 300 its a Puig. Just got mine. Its a little upright for my taste but does a good job. Mechanic said designed that way so passenger not blasted in face.
Seems like it drops into holes after mirrors are removed than supplied brackets used to re-mount mirrors.
« Last Edit: April 08, 2017, 09:12:29 PM by scorion57 »
wheels
  • USA, NC, Raleigh
Re: Speed Update (78MPH) Kymco Puig (Pics)
« Reply #1 on: May 24, 2017, 10:51:13 PM »
I have the Puig ST, i think.
Two issues.
Screen is too flat, you can bend it by rotating the mounts inward.
Screen is too upright, you can fabricate a replacement (collar with hole) out of 1/2 " plastic grey pipe.  It takes some dremel/drill work but I changed the angle about 20 degrees flater .  You will loose about an inch in height.
Note, had the scoot up to 92mph (crouched with no screen), figure you can squees 95 max.   I have not tried going over 80mph with the screen .... yet.    lol
2012  DT 300i  26K miles,  Bestem 929, Biondi w/s, LED brake/tail,turn, OEM mirrors fairing mount, removed buttstop
2015  GTi300  7K miles, Bestem 929 case, PUIG TS w/s, mirrors mounted to w/s, led DRLs in windguards
2014  Honda CTX700,  35Kmiles, many mods
