Author Topic: Lighter Charger? FIXED!  (Read 844 times)
Nireen
« on: April 07, 2017, 09:32:38 AM »
Hi any suggestions on what it is and how to fix the lighter charger inside the glove box?  It has never worked for me right from the start and I just let it go.
« Last Edit: April 08, 2017, 06:35:59 AM by Nireen »
Kat :)
Mr. Paul
Re: Lighter Charger? How to fix?
« Reply #1 on: April 07, 2017, 09:52:56 AM »
Didja check the fuse Kat?
2009 Kymco People 150
1993 Honda Helix
Nireen
« Reply #2 on: April 07, 2017, 10:09:28 AM »
OK where is the fuse, is it under the front dash cover?
Kat :)
Nireen
« Reply #3 on: April 07, 2017, 12:11:11 PM »
 I broke two plastic parts one one that black triangle cover (one side snapped!) the other on that black piece at the bottom of the front cover. Sigh
« Last Edit: April 07, 2017, 12:35:15 PM by Nireen »
Kat :)
« Reply #4 on: April 07, 2017, 01:02:17 PM »
The whole front cap must be removed (the white pointy part with the headlights) to access the fuse.
Nireen
« Reply #5 on: April 07, 2017, 01:40:14 PM »
Thank you Karl, yeah I got it and broke to plastic parts!! :P I heard also that changing the 0.2A fuse to a 1A fuse will work better for this.  What do you think?
Kat :)
« Reply #6 on: April 07, 2017, 01:50:00 PM »
The wires are big enough to handle 1 amp, in my opinion. I, on the other hand, wired mine direct to the battery with a 10 amp fuse and its holder right at the battery. This powers the Wolo horn and allows a battery charger to be plugged into that outlet. Number 12 insulated wire, red. This setup eliminates a lot of heartburn. De dee put a fuse holder inside the glove box which was genius! These .2 amp fuses hidden under nearly impossible to remove bodywork had to be designed by a committee.
Nireen
« Reply #7 on: April 07, 2017, 02:07:51 PM »
:D yes, I had hooked up my own charger from the battery last year and it sits under my seat.  It works well but I just wanted to fix this one in the glove box it I could.
Kat :)
Nireen
« Reply #8 on: April 07, 2017, 05:45:07 PM »
Fuse changed and now it works! Yay!
Kat :)
Mr. Paul
« Reply #9 on: April 07, 2017, 08:17:45 PM »
Way to go Kat!!
1993 Honda Helix
Nireen
« Reply #10 on: April 07, 2017, 09:32:57 PM »
Pounding my chest LOL! Thanks Paul :D
Way to go Kat!!
Kat :)
Mr. Paul
« Reply #11 on: April 07, 2017, 10:45:21 PM »
 ;D ;D ;D
1993 Honda Helix
