Author Topic: Seafoam - how often do you use it?  (Read 1899 times)
GLV55
« on: April 08, 2017, 03:02:54 AM »
I have a 150cc GY6 engine (carburated) in my Lance/SYM PCH, and I usually use 91 octane non-ethanol gas in my 1.3 gallon tank. Through the winter I add Sta-bil to the gas and let it run a few minutes to get it into the entire system. This has worked very well, and my scooter always starts right up each spring.
I plan on adding the Seafoam directly into the tank when I fill up to help clean the carb and maintain the fuel lines. Just wondering how often I should add it to the gas...every fill up? Once a month? Every other month? Every so many miles? I don't want to over-do it, just do it right. Your experience and wisdom is much appreciated. Thanks!
2014 Lance PCH 150
2007 Kymco People 150 (totaled by a drunk, Oct. 2013)
Nampa, ID
paceneedsstides
Re: Seafoam - how often do you use it?
« Reply #1 on: April 08, 2017, 06:26:43 AM »
I don't run it anymore I did for a bit bout a cap each tank when I first got the Like but I ran through a tank on it and now on the S9 every day or other day so really no need for anything just clean my carb once every couple months or so.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
Mr. Paul
« Reply #2 on: April 08, 2017, 11:09:52 AM »
If you run 91 octane non-ethanol gas and you regularly ride your scooter, you really do not need Seafoam at all.  I ride almost daily and I use Seafoam just occasionally. You have no worries.
2009 Kymco People 150
1993 Honda Helix
GLV55
« Reply #3 on: April 08, 2017, 02:48:28 PM »
Thanks, pace and Paul, sounds like I just need to add it a few times per year. Good to know, and thanks for the info.
2014 Lance PCH 150
Nampa, ID
airshot
« Reply #4 on: April 08, 2017, 04:14:23 PM »
    Seafoam's real intention is to reduce carbon build up in 2 cycle engines. For actual carb cleaning there are better products. If you run a 2 stroke engine then seafoam is the product you need using it a few times thru the year. Best if used right before the end of your riding season.
« Reply #5 on: April 09, 2017, 08:12:19 PM »
got some water in the gas or dirt ???  put 1 Ounce seafoam to 1 gal gas today I hope it fixes the sputtering when starting from a stop,.
GLV55
« Reply #6 on: April 10, 2017, 02:18:01 AM »
Let us know what happens, de dee.
2014 Lance PCH 150
Nampa, ID
lilzip24
« Reply #7 on: April 10, 2017, 07:46:22 PM »
Using the Sea Foam every fill up is overkill unless you just aren't riding the scooter. Depending on how often you ride, only a couple times a year is good.
2016 Kymco K-Pipe 125
2014 Suzuki DL1000A VStrom
2007 Suzuki VL800C C50
« Reply #8 on: April 11, 2017, 01:53:34 PM »
I do seafoam maybe 4 times a year.you dont wana over kill.It will eat the rubber gaskets.And use it to store the scoot is ok as long as you go out and start it up a few times.
GLV55
« Reply #9 on: April 11, 2017, 06:13:55 PM »
Thanks for all the good advice, folks. Love this forum!!
2014 Lance PCH 150
Nampa, ID
TroutBum
  • 2012 Like 200i (sold)
« Reply #10 on: April 11, 2017, 08:15:04 PM »
On average I pour a shot glass amount in with every 4th tank or so. It depends on my riding habits. When I'm working I tend to use it more often as the scooter sits until the weekends. When I am between assignments and have time on my hands I can burn through a tank or two or three in a week so I don't bother with Seafoam.
