Author Topic: Kymco Agility 16+ top speed  (Read 4864 times)
Dsoul82
« on: April 09, 2017, 06:40:39 PM »
Hello,
I have Kymco agility 16+, 50cc 2 stroke. Year is 2015. Where he have restrictions?.
The restriction on variator is removed. Currently it is malossi wild lion exhaust.   The maximum speed is 60km/h. I need 10-15km/h so i can pass one part oh highway to get to my job.
What I can expected on top speed with Naraku or Malossi big bore kit 70ccm.  Do I need to change carb ?
Maybe if stays money also change variator.
Thnx 4 help!
Tromper
  • Seattlish
Re: Kymco Agility 16+ top speed
« Reply #1 on: April 10, 2017, 12:51:53 AM »
Dsoul, 60kph/37ish MPH is not bad speed out of a two stroke 50.  You can get a bit better by replacing the CDI, & upping your jet size.
Sorry I cannot provide specifics, but they're here on the forum somewhere if you google it or do some searching in the forum yourself.
http://www.kymcoforum.com/index.php?topic=6198.msg62708#msg62708 is the big one as I recall.
Yeah the big bore kit would get you a chunk of power as well, but more at the low end from all tell.  I had an old moped with a 70cc kit from the era (long time ago) in it that definitely had nice low end, but still topped out (unrestricted) about 45ish mph with a long ramp up.  Acceleration was good up to city speeds, but really took a while after I got to 40.
By your choice of metric units I'd assume that you're not in the U.S.,  so I'm not dead sure of the laws there, but in the U.S. even the big bore kit would require a license.  Really in most areas you can get pulled if you're going over 30mph on a "moped" license or local equivalent.
All that noted, unless you have a licensing restriction of some kind or other you can forgo all the messing around and pick up the 125 or better version of the agility of any number of other bikes and get the same thing with no loss of MPG, no messing around, & lower detonation factor then running fully topped out a on two stroke all the time.
My old S200 was great up to about 50-55mph, & topped 60ish.  This is pretty consistent for 150ccish bikes; albeit it was a 163cc, & just like with the 70cc kit I had a bit better bottom end.  The 125's are a bit slower, & my SYM's a bit faster.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
ThehardcoreFTW
  • Verstand op nul, blik op oneindig
« Reply #2 on: April 10, 2017, 07:12:46 PM »
Derestricted two strokes 50cc should go about 75 gps, did you check if all the restrictions (small jet, airbox restriction, exhaust restriction, perhaps different roller weights) are gone?
Dsoul82
« Reply #3 on: April 10, 2017, 07:23:42 PM »
I was at Kymco service and told me that scooter can go more than this that what I want from this scooter. I think they check all restrictions but only I think  :D Today I messured with GPS top speed and only 55km/h.
« Reply #4 on: April 11, 2017, 01:57:35 PM »
I never knew the agilty came in a 2 stroke.
vinineves
« Reply #5 on: June 20, 2017, 11:06:27 AM »
Guys,
Do you know what's the handlebar diameter of Kymco Agility 16+ 200i?
I want to install a side mirror on it and need to know if that would fit on it, see the model in the link below;
http://www.ebay.com.au/itm/7-8-22mm-Universal-Motorcycle-Handle-Bar-End-Rear-Side-View-Mirrors-Cafe-Racer-/252892774890?hash=item3ae19581ea:g:UkEAAOSwvihY~Zqh
Cheers!
Vini
mury
« Reply #6 on: June 22, 2017, 12:37:28 PM »
My is derestricted, except maybe the main jet / I have not checked it yet / it raises 50-55 on a straight road, 60-62 down slightly. I am 110 kg. I think I'll check the jet and it's time for Malossi Multivar . Just ask, should I change the jet,if i make another setting of carb
« Last Edit: June 22, 2017, 12:54:02 PM by mury »
