Author Topic: Polini clutch, anyone?  (Read 2747 times)
MJR
Re: Polini clutch, anyone?
« Reply #15 on: April 19, 2017, 01:06:39 PM »
You need a special tool for the CVT tho.
If you are talking about a clutch holder you can make one with some metal bar and bolts.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
sissymary
« Reply #16 on: April 24, 2017, 01:31:53 PM »
I bought an electric impact wrench years ago at harbor freight for about $40.00 Works perfect. Zips on and off clutch and variator in seconds. No need for any holding tools. :-*
MJR
« Reply #17 on: April 24, 2017, 02:13:30 PM »
For removing an impact is fine but it could over torque putting it back on so a holder and torque wrench is recommended.
sissymary
« Reply #18 on: May 11, 2017, 01:50:09 PM »
Mine is not powerful enough to do that. It is not a shop compressed air unit. Has worked many times with no issues. I would put some medium strength lock tight on the threads before install also. Make sure it is good for heat areas. As varo gets pretty hot. Let set up over night before starting. Do not use red permanent lock thread. :-*
