Author Topic: Polini high Speed - Kymco Super 8 4 stroke  (Read 1125 times)
waqr
« on: April 26, 2017, 08:42:34 AM »
I`m about to install this in my scooter but noticed that the drive boss i 39mm long compared to 38mm of the Kymco original drive boss. This I guess means that I will get 1mm less splines to use on the crankshaft. As I can see there is already a tight fit with the 38mm boss so I am worried that I will strip the splines when using the longer drive boss.
Can I use the Polini kit with my stock boss?
www.twostroke.se/product.asp?product=14123
AylmerFreerider
Re: Polini high Speed - Kymco Super 8 4 stroke
« Reply #1 on: May 17, 2017, 03:53:38 PM »
Did you do this?  I am about to do it today and see what happens.
I also grabbed a non restricted exhaust pipe as well
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
Chris0381
« Reply #2 on: May 18, 2017, 10:04:17 PM »
bump on thsi
I would like to buy a performance variator also. The only thing stopping me is that I dont know if I should use the stock boss or the boss that come with the new variator.
Also do you use the stock belt or d oyou need to buy a different one thats made of kevlar?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
AylmerFreerider
« Reply #3 on: May 23, 2017, 02:07:50 PM »
I have it installed and looking at the the 39mm boss it was to long.  It was covering some of the splines.  So I used the Kymco 38mm smooth boss that came with my scooter.  I also noticed that the rollers were the same weight so I may look into going with a 6 gram roller depending on how things go.  Both the Polini and stock rollers were 6.9 grams
Am going to have my first ride this morning with it to work.  Will let you know how it goes.
2015 Super 8 50R
72cc BBK
AylmerFreerider
« Reply #4 on: May 25, 2017, 12:47:48 AM »
So my scooter goes a little faster on the flat.  I did use the stock variator.  I am accelerating faster but I think I need lighter rollers.  I am going to try 6gr I think.
I am still using the stock belt.  I did upgrade the exhaust as well. I will need to up my main jet now as well.  It is currently an 82.  Guy at the shop recommended going to a 92 with the new exhaust.
2015 Super 8 50R
72cc BBK
