Author Topic: Need guidance on malossi 19 mm carb install  (Read 705 times)
crave
« on: April 29, 2017, 05:39:07 PM »
Just ordered 19mm malossi carb.
https://scooterpartsco.com/malossi/malossi-master-part-list/malossi-19mm-carburetor-kit-for-kymco-50cc-2-stroke?zenid=2968b3b656ed7a1f7adef32f362fe0bc
The instructions aren't clear.
So I got two cables in the kit. No idea where they should go and a manual choke. Anyone done this install before?
Mr. Paul
Re: Need guidance on malossi 19 mm carb install
« Reply #1 on: April 29, 2017, 07:11:04 PM »
One cable should be for the throttle, I would just use the existing one from your scooter. The other should be for the manual choke. Will probably have to drill a hole somewhere and install the push/pull mechanism for the choke.
2009 Kymco People 150
1993 Honda Helix
