Author Topic: Anyone had a fuel pump fail?  (Read 399 times)
Mr. Paul
« on: April 30, 2017, 11:33:41 PM »
Have any of you folks had a fuel pump fail, and if so, what were the symptoms. Did it go out all at once or was it an intermittent problem first?
2009 Kymco People 150
1993 Honda Helix
Re: Anyone had a fuel pump fail?
« Reply #1 on: May 02, 2017, 11:11:22 AM »
This will be only a partial help....
If you determine that fuel pump indeed is failing....I bought from an American  co. on ebay a perfectly fine, matching, replacement for much less than the assembly cost from Kymco. I only replaced the pump itself,  with new HighFlow pump and filter. (@$65....yeah plenty of cheaper ones, but if I'm going all the way into the tank, better quality seemed wise. ) Pump was in the tank.
FYI, My symptoms of intermittent cutting out were actually due to a failing throttle position sensor.
« Last Edit: May 02, 2017, 11:25:18 AM by Stig »
