Author Topic: help remove valve cover 500 ri 2011 model  (Read 1109 times)
Ge.k
« on: May 06, 2017, 08:27:05 AM »
my head gasket is blown the garage want to much money is not worth to fix it so i decied to do it my self/
i got stuck at valve cover it wont get out
any help
here some pictures
Redk
Re: help remove valve cover 500 ri 2011 model
« Reply #1 on: May 06, 2017, 09:06:22 AM »
I have never made this repair...
If you disconnect the rear shock or compress it, will the top of the engine lower to allow that cover to be removed?
Is it required that the motor mounts be disconnected to remove that cover?
Hope you get a proper answer quickly !
redk
willembop
« Reply #2 on: May 06, 2017, 12:33:23 PM »
As the previous reply indicated, if you disconnect the rear shocks and move the rear wheel all the way up (or down, maybe, I don't exactly remember), there is room to remove the valve cover. I had to remove head bolts when I replaced my cams. You need to move the rear wheel up and down as required to withdraw the long head bolts. Put some wood spacers under the rear tire to keep it in place.
Ge.k
« Reply #3 on: May 06, 2017, 01:06:41 PM »
Thank you , ill try it and update you tomorrow.
Redk
« Reply #4 on: May 06, 2017, 06:10:14 PM »
Great !
I am looking forward to an update.
redk
Ge.k
« Reply #5 on: May 07, 2017, 08:09:06 AM »
Thank you for helping, I tried this method, it worked fine, I needed two people for it, I dismantled the shocks and put it on the wheels and my friend added weight to the back and the engine went down, I turned the valve around 180 degrees because the opening of the breathing Interrupted, then it slide down alone with some shakes and the rear thanks alot.
sorry for my bad english
ill keep update
here some pictures
http://imgur.com/a/UU7t1
Ge.k
« Reply #6 on: May 09, 2017, 06:06:11 PM »
any help with finding thermostat ??
all ebay is for 250 and 300 models no one have for 500 why?
Redk
« Reply #7 on: May 09, 2017, 07:06:25 PM »
Glad to see progress !
Looks like the right time to change the oil, also...
redk
