Author Topic: cvt roller question ( doctor pulley sliding rollers )  (Read 1645 times)
houg
« on: May 07, 2017, 02:34:05 PM »
i have a 2002 kymco 50cc cobra racer i just installed a set of doctor pulleys 16x3 6.5 gram sliding rollers now when i take off the engine revs like hell and the take off is way worse then it was with the round rollers and top speed isnt any better than the round rollers
did i install the wrong weights????   im not sure what weight the ones were that were in it, the cvt is all so derestricted
ronigj
    • Super 8 Philippines Motorcycle, Club Inc.
Re: cvt roller question ( doctor pulley sliding rollers )
« Reply #1 on: May 07, 2017, 03:00:11 PM »
See illustration
Everything will be all right
ronigj
« Reply #2 on: May 07, 2017, 03:10:38 PM »
ronigj
« Reply #3 on: May 07, 2017, 03:10:57 PM »
ronigj
« Reply #4 on: May 07, 2017, 03:11:15 PM »
Mr. Paul
« Reply #5 on: May 07, 2017, 06:09:33 PM »
Chances are you installed the sliders incorrectly or they shifted during installation. I would recommend you pull them out, and carefully look at the installation pictures, and put them back in. Be careful to hold the variator together when you install it back into you scooter to prevent the sliders from changing positions. I am not a big fan of the sliders. My personal experience is that they may "feel" better in a particular rpm range but in reality do not perform better than rollers.
2009 Kymco People 150
1993 Honda Helix
houg
« Reply #6 on: May 07, 2017, 08:21:47 PM »
I definitely had them installed according to directions
Mr. Paul
« Reply #7 on: May 07, 2017, 11:08:35 PM »
The original rollers are 8.5 gram, so I think the 6.5 sliders may be a little too light. If the rollers performed better, that's what I would go with. Hope that helps ya. BTW, I hadn't heard of the Cobra before. Cool little scooter!
http://www.kymcopartsmonster.com/pages/OemParts?aribrand=KYM#/Kymco_USA/SF10AG_Cobra_Racer_50/Variator/2K01150005/01150013
1993 Honda Helix
paceneedsstides
« Reply #8 on: May 08, 2017, 01:50:30 AM »
I like the Sliders better than rollers in fact bout to order a new set my guess is you got to light a set and so it's not pushing variator all the way out and revving higher than it should.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
Mr. Paul
« Reply #9 on: May 08, 2017, 01:58:33 AM »
My rollers can beat up your sliders Pace. And my oil is better than yours! ;)
1993 Honda Helix
paceneedsstides
« Reply #10 on: May 08, 2017, 02:03:15 AM »
My Slipping Sliders to fast for your rock n rollers and you gotta change your oil when it gets old mines forver young cuz I burn it!!!!!!
94 main jet
Malossi Multivar
Stage 6 upgear kit
MJR
« Reply #11 on: May 08, 2017, 04:17:49 AM »
If the stock rollers were 8.5 gram as Mr. Paul said then about 7.5 gram would be closest to 10% lighter that most people use as a guide. Also as suggested they may have been put in right but slipped out of place/flipped if tension wasn't held putting it back together was what I think Mr. Paul was getting at.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
« Reply #12 on: May 08, 2017, 11:29:32 AM »
Not sure what kind of magic the sliders can do with a small scooter engine.....seems like not much extra to borrow  from on either end of the rev range....but on big scoots will lower revs at highway speeds.
Redk
« Reply #13 on: May 08, 2017, 12:24:59 PM »
Stig, considering there's really no substitute for displacement, smaller contenders must go to ratio changes to stay in the game.
Change in the variator, and clutch, will allow a higher rpm for a start, and more initial speed out of the gate, and, the dreaded hills.
All those minor considerations of power to weight ratio kinda go away with displacement.  :-)
Double bonus if the configuration allows a closer ratio at full rpm for those glorious long, level straight-a-ways with a tailwind!
Yahoo !
redk
Mobbin' our TFR in the hood.
