Author Topic: I am stumped!  (Read 3506 times)
houg
Re: I am stumped!
« Reply #15 on: May 11, 2017, 01:23:48 PM »
dirt in carb   drain or clean your carb
Mr. Paul
Re: I am stumped!
« Reply #16 on: May 21, 2017, 01:28:19 AM »
Thanks everyone for the replies. I really, really appreciate the feedback. I have the problem solved. The carb jets were clean, the fuel flow seemed good, the manifold was not leaking. I checked the plug. It was in good shape, except it was white. It wasn't white before, but I just changed to a non-iridium. I checked the fuel mixture screw. It was turned almost all the way towards lean! I backed it up 2 1/2 turns and all is good now.  :) :) :) Now that I know, I feel as if I should have known. I think.
2009 Kymco People 150
1993 Honda Helix
Re: I am stumped!
« Reply #17 on: May 21, 2017, 01:47:28 AM »
Cannot argue with success, Mr. Paul, but idle mix screw affecting beyond idle throttle seems illogical (Spock again!).
Mr. Paul
Re: I am stumped!
« Reply #18 on: May 21, 2017, 07:01:26 PM »
Darnit Jim, I'm a scooterist, not a doctor ;D    Gimme some feedback here Karl; The idle screw on the Helix controls how much fuel goes into the intake during low speed operation but, being independent of the enrichment circuit, does not cut fuel to this port during high speed. Therefore, the high speed operation of the engine relies on the assistance of the low speed idle system to add to the overall enrichment of the combustible mixture. If you cut the fuel to the low speed system, it would be logical to assume that fuel is also cut to the final combustible product at high rpms.
1993 Honda Helix
tortoise
Re: I am stumped!
« Reply #19 on: May 21, 2017, 08:01:04 PM »
Somewhat odd how the pilot/low-speed mixture screw would effect what was described as a mid-range issue?
Re: I am stumped!
« Reply #20 on: May 21, 2017, 08:25:31 PM »
I gotta admit there IS some overlap in the idle and run circuits.......
Mr. Paul
Re: I am stumped!
« Reply #21 on: May 21, 2017, 08:31:37 PM »
Karl, on the Helix the idle port does not shut off when the high and mid kicks in. It continues to add fuel to the mix. Seems like to restrict the port, would be to restrict the fuel added to the mix at all speeds. I will definitely keep an eye on it. Going to ride it some then pull the plug to verify. I respect your opinions so I am still leaving the option open that I could very well be wrong. Right now it is running great.
1993 Honda Helix
Re: I am stumped!
« Reply #22 on: May 21, 2017, 08:41:08 PM »
Wait til I post my diagnosis boo-boo's on another single cylinder engine! You'll never speak to me again!
Mr. Paul
Re: I am stumped!
« Reply #23 on: May 21, 2017, 10:33:23 PM »
I will always speak to you Karl, no matter what. Just remember that I am 100% correct, 60% of the time. You have forgotten more than I know. (Hats a compliment)
1993 Honda Helix
Re: I am stumped!
« Reply #24 on: May 22, 2017, 12:22:41 AM »
Aw, you say that to all the girls! Except Nireen!
Mr. Paul
Re: I am stumped!
« Reply #25 on: May 22, 2017, 12:44:57 AM »
Shhh. She might be eadingrae this.
1993 Honda Helix
DIRKHUNT
Re: I am stumped!
« Reply #26 on: May 22, 2017, 07:19:08 PM »
Had similar isses with my Bajaj Chetak
Turned out to be the plug wire
Sent from my SM-G900P using Tapatalk
Redk
Re: I am stumped!
« Reply #27 on: May 22, 2017, 09:05:38 PM »
Boo-boos ?
I've made a few.
Actually, too many to mention.
1 example only.
Many years ago a friend was upset his car just wouldn't go...  it started quickly, never let him down, but had very little power going down the road.
I drove it, and could not see anything wrong, either.
I suggested the transmission could be bad, which he refused to accept, mostly because of the expense.
That night, a competent mechanic visited, and we went out to look at the car.
Lifted the hood, started the engine, and it lit up like a Christmas tree in the engine compartment !
Bad sparkplug wires.
Mea culpa.
redk
ole two wheels
  • ole two wheels
Re: I am stumped!
« Reply #28 on: May 23, 2017, 02:06:25 AM »
If you suspect Putin, just check with Trump. All the democrats will tell you, they are  in kahoots..
hee hee.
Mac.......didn't say it
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
h2ou8n4
Re: I am stumped!
« Reply #29 on: May 23, 2017, 02:30:00 AM »
Just a stab in the dark, but two possibilities:
1. I had a big Suzuki road bike that behaved like that and the problem was the ignition coils.
2. Another big road bike, a Yamaha, had a fuel line running from the tank to the carbs that was exposed to engine heat. At a certain temperature, the line would kink resulting in reduced power.
When you're feeling mighty low
like your better days are past
Just take a ride in your underwear
and you'll feel better fast!
