Author Topic: grinding noise  (Read 2228 times)
jesseg010
grinding noise
« on: May 08, 2017, 10:30:04 PM »
after fixing the carb I took it for a ride of course. half way down the road I heard a high winding nose then it went dead. won't start now similar to the battery being dead. only clicks. anyone know what I broke?
« Last Edit: May 25, 2017, 05:04:13 PM by jesseg010 »
Re: very high winding nose
« Reply #1 on: May 09, 2017, 04:37:37 AM »
Not enough info.
jesseg010
« Reply #2 on: May 09, 2017, 09:20:37 PM »
the winding nose came from the engine compartment  I believe it may have been the gear  box
« Reply #3 on: May 09, 2017, 10:23:07 PM »
Oil in gearbox?
jesseg010
« Reply #4 on: May 09, 2017, 11:24:29 PM »
here's something else too. I can hear the grinding sound when I attempt to start the bike again too. so that is something new.
« Reply #5 on: May 10, 2017, 01:33:06 AM »
Grinding noise the same as high winding noise? We talkin' about the same noise? What gearbox are you referring?
Mr. Paul
« Reply #6 on: May 14, 2017, 01:00:21 AM »
It looks like Jess is using a translation software. High winding noise may be "high wind noise" or a sound of an air leak somewhere. Just guessing.
2009 Kymco People 150
1993 Honda Helix
jesseg010
« Reply #7 on: May 18, 2017, 06:06:39 AM »
update
the belt is fine. when I try to start the bike there is a heavy grinding sound. I took the starter out to test it and the starter spins fine. put it back in. same grinding noise. I'm suspecting bearings. but not 100%. any thoughts?
« Reply #8 on: May 18, 2017, 12:32:04 PM »
What else do you observe when activating the starter? You hear the grinding noise but does the engine spin like it should? Do you notice any sparks or smoke from battery to starter?
ole two wheels
  • ole two wheels
« Reply #9 on: May 18, 2017, 03:31:21 PM »
Just wondering if you looked at the small gear on the starter? If the teeth are worn badly, that could cause a grinding noise. If you hear a winding or singing sound upon deceleration, especially at high speed, this is the final reduction gears in the gear box and even with the proper amount of gear lube, this is normal. I have often wondered why Kymco calls for only 7.1 oz. of gear lube in the gearbox on my DT300, when every other brand of scooter is , fill to overflow?? Without actually hearing a noise or sound, it is difficult to pinpoint where it's coming from or what causes it. I wish you luck with this and welcome to the jungle, er or forum.
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
Redk
« Reply #10 on: May 18, 2017, 06:21:16 PM »
Seems like a bendix drive/starter problem ???
yes, need more info.
redk
jesseg010
« Reply #11 on: May 19, 2017, 09:23:39 PM »
so just to recap here.
the bike was sitting all winter. started up fine no noise no trouble but the  first drive I heard a high winding/grinding noise that increase in pitch as I accelerated then suddenly pinged then it died. come to find out if also drained my battery. after charging the battery and attempting to start the bike there is a low tone grinding noise that I can also feel. asks the bike won't turn over. it's not the starter or bendex they were removed and tested.
« Last Edit: May 27, 2017, 09:27:23 PM by jesseg010 »
