Author Topic: higher speed?  (Read 3405 times)
Chris0381
Re: higher speed?
« Reply #15 on: May 18, 2017, 10:06:21 PM »
even on a good running 49cc scooter, expect 27 MPH or lower on the steeper hills.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
mlsmith2924
Re: higher speed?
« Reply #16 on: May 21, 2017, 03:26:22 AM »
So I have purchased a Polini High Speed Variator and Technigas Silent Pro Exhaust.  mlsmith2924 I will let you know how this goes.
Tseg I think the Variator should clear the rev issue when you disconnect the Purple wire.
I will also look at a bigger jet as well to match the exhaust.
Yes! please do good sir
2016 Super 8 50X
washer in intake manifold removed, CDI wire cut, re-jetted, smooth variator boss
AylmerFreerider
Re: higher speed?
« Reply #17 on: May 23, 2017, 02:04:11 PM »
Everything on and in place.  I still haven't removed the washer in the intake yet.
Waiting till I can get a bigger jet first to make up for the extra air.
Will let you know how the my first ride goes this morning.
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
3 x 1" Air Filter additions to Air Box
AylmerFreerider
Re: higher speed?
« Reply #18 on: May 25, 2017, 12:54:59 AM »
So what I have done so far.
Replaced Boss
Replaced Variator with Polini high speed (using stock smooth boss) and 6.9 gram rollers
Replaced original 80 jet with 82 jet (this came with the scooter when I purchased it)
Replaced stock exhaust with Technigas Silent Pro
Removed washer from intake valve.
What I noticed from test run.
Better acceleration, holding 37 mph on flats (was a quick test ride so motor never got warm)
I was getting a popping noise before I took the washer out.  When driving it with that I did hit 43.5mph on a down hill
Next I am going to try a lighter roller, maybe 6 or 6.5 grams
2015 Super 8 50R
72cc BBK
mlsmith2924
Re: higher speed?
« Reply #19 on: July 12, 2017, 12:05:12 AM »
Nice, I finally grew some balls and cut the CDI wire. There was a definite power gain and I hit 40 on a flat, 42 downhill! thats all I really hoped because I live in Boston and theres a street light every 5 feet.
2016 Super 8 50X
