Author Topic: Squeek  (Read 1114 times)
Redk
Squeek
« on: May 12, 2017, 01:44:37 PM »
A very slight chamfer, applied with a file, to the leading edge of brake shoes and disk brake pads may ease a little of the squeaking.
Some disk brake pad sets come with a liquid rubber type goo for application to the backside of the pads to dampen noise...
Machinery really should not squeak, though.  It's probably a sign that inspection is warranted and possible application of lubricant.
redk
MJR
Re: Squeek
« Reply #1 on: May 12, 2017, 03:55:30 PM »
It happens when you have semi mettalic brakes pads. Two of my B650's make noise and it annoys me. I think I might have to change the pads to make it go away.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
ole two wheels
  • ole two wheels
Re: Squeek
« Reply #2 on: May 12, 2017, 10:44:26 PM »
Might want to look at some ceramic pads. No squeak or dust and do not generate as much heat. I got tired of my front chrome alloys turning black with brake dust, on my pick-up. The guy at the auto parts store suggested I try ceramic pads and I've never looked back.
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
Redk
Re: Squeek
« Reply #3 on: May 15, 2017, 09:16:20 AM »
MJR, I have seen other people make large X's using a file across the shoes, attempting to quiet squeaks.
I will Not warrant the mod to safety components.
redk
Re: Squeek
« Reply #4 on: May 23, 2017, 08:53:48 PM »
No auto expert here....but was informed long ago that disc brake noise is due to pad vibrating in its seat. Fix is with a shim to back-side of pad...to dampen contact/vibration.....
Noise source is from back of pad, not face/disc side.
Had a 2002 BMW...we used teflon like shim ....silenced the brakes...tip was from a good mechanic.
big blue
Re: Squeek
« Reply #5 on: May 24, 2017, 04:30:24 AM »
Back to days of Alfa Romeos with metallic pads, copper grease on the back of the pads.
