Author Topic: ..scoot shuts down..  (Read 9074 times)
art
Re: ..scoot shuts down..
« Reply #15 on: June 29, 2010, 11:58:49 PM »
We got 3 harbor frieghts within 20 miles.there cheap but get the job done.
« Reply #16 on: June 30, 2010, 12:00:41 AM »
... We got 3 harbor frieghts within 20 miles
..you must live near th' coast...that would make sense...lol..
art
« Reply #17 on: June 30, 2010, 12:14:31 AM »
They don't call it portland for nothing!were actually bout an hour and a half from the beach,But we are surrounded by major rivers for transport.
« Reply #18 on: June 30, 2010, 12:16:50 AM »
...duh...i knew you were in portland...i'm stupid...lol..
 :o
« Reply #19 on: June 30, 2010, 04:19:08 AM »
Sorry it took so long to find the post slinger, Get a small bottle of Indian Shellac at any auto parts. Your reed cage will have an "o" ring on the engine side, and a peper gasket on top. They work by flexing open on the up stroke to let fuel into the cases, and sealing shut on the down stroke so that mix is forced into the comb. chamber thru the ports. Your oem reeds are stainless steel, and can crack if there is a sudden change in rpms. (IE the belt breaking) Check them asap. If it breaks off it will wind up inside the cases. If you do find a broken reed... Order a set of Boysen carbon fiber blanks at .030-.033 thick. You can easily trace, and cut the blank to fit your cage, and have a quicker response from the throttle, as well as a more stable running top end. Check for a leak around the carb, and cage too before you take it apart. One of those vacuum testers like Shaka made will prove to be you next best friend w/ a 2t. From sitting so long it may have dry seals on the crank.
« Reply #20 on: June 30, 2010, 04:28:10 AM »
..thanx z....
..and where's the best place to get those blanks..
..carb and intake seals are all gooood...
..would i be leaking any fluid at the crank seal if it were bad?
« Reply #21 on: June 30, 2010, 04:32:46 AM »
...here we go baby!!!...
 ;D :o ;D
« Reply #22 on: June 30, 2010, 04:35:53 AM »
..vacuum tester...
..compression tester...
..ain't it christmas yet??
« Reply #23 on: June 30, 2010, 04:36:46 AM »
Yuo would NOT see any fluid as it is all fuel, and 2t oil in there. It will allow extra air in the case tho leaning out your mix. The reeds can be had at any shop that sells dirt bikes but I get mine from  http://www.rivamotorsports.com/   and I think you can get them from JC Wittney now too
« Reply #24 on: June 30, 2010, 04:38:03 AM »
..really..any dirt-bike shop...i need reeds now...lol...coool...
« Reply #25 on: June 30, 2010, 04:38:32 AM »
Tell BP you are soooo upset about the spill you cannot think straight. They just may send you some hush money to calm you down...
« Reply #26 on: June 30, 2010, 04:39:38 AM »
...and i still got that damned link open ...just stopped posting.....
..i hadda vent...
« Reply #27 on: June 30, 2010, 04:40:55 AM »
They will be about 25-30 bucks for the blanks. After you cut them use some devcon epoxy to smear on the cut edges. That will re-seal the raw fiber, and make them last just about forever.
« Reply #28 on: June 30, 2010, 04:42:55 AM »
..yeah,..i like longevity...
« Reply #29 on: June 30, 2010, 04:44:50 AM »
I have had them in every 2t I have ever owned. Somewhere around 30ish bikes, and have NEVER had one fail.
