Author Topic: ..scoot shuts down..  (Read 9069 times)
art
Re: ..scoot shuts down..
« Reply #30 on: June 30, 2010, 04:49:20 AM »
Ha! keep forgetting about word no 2t ever?Hey zombie did you see my post about the aero 125
« Reply #31 on: June 30, 2010, 04:58:36 AM »
Yeah man I sent you a pm about it. Should be on the MY MESSAGES. I am definitely interested. Pm me back w/ more info!
art
« Reply #32 on: June 30, 2010, 05:06:05 AM »
Cool leaving town tomarrow i'll let you know whats up not realy mine,but posesion is 9/10th of the law!
« Reply #33 on: June 30, 2010, 02:50:03 PM »
devcon epoxy to smear on the cut edges..
...auto parts store also?
« Reply #34 on: June 30, 2010, 04:15:08 PM »
..so i found the Boysen carbon fiber reeds at a local honda shop...
..theyre not blanks, but i'd bet they're larger than what i need, and can cut them to fit..
..anybody say yes??
« Reply #35 on: June 30, 2010, 07:44:10 PM »
Before you buy them check the thickness. You need .030-.033, Any thicker will ruin your idle circuit. Thinner will ruin your top end. It is a balance act just like the cvt. The epoxy can be found almost anywhere. It is the type in the 2 barrel syringe looking thingy. I use the SLOW cure type, and give it over night to cure. Just put a bit on your finger tips, and wipe it over the raw edge. You don't want any extra on the reeds, as it will affect the spring action in them. BE SURE to keep ALL the edges/cuts ROUNDED. You dont want any sharp intersections, as that would be a place for a crack to start. A little emory cloth will round up all the angles. This mod is about equal to doing rollers, as far as results go. Its worth the effort.
« Reply #36 on: July 05, 2010, 05:26:10 PM »
..i went ahead and ordered the stock reeds and gaskets from stadium...
..got two new long drive belts coming tomorrow...
..one for each of my ponies...
..yee-haaa!
 ;D
« Reply #37 on: July 15, 2010, 10:47:55 PM »
...okay, scoot shut down today, and will not fire...
..getting fuel to the carb, getting spark...
..starter spins the engine over and over and over, but it will not fire...
..spark plug remains dry, and i see nothing at all wet in the cylinder...
..pulled the reed valve, and the reed petals look OKAY!....
..any ideas?
..what am i missing??
Agent Bob
« Reply #38 on: July 15, 2010, 11:34:31 PM »
My experience with a hissing sound comes from cars, and that was a vacuum leak.
art
« Reply #39 on: July 16, 2010, 01:40:30 AM »
No fuel to carb maybe, did you try starting fluid or some other direct approach.Try that first if you havn't allready.
« Reply #40 on: July 16, 2010, 01:55:19 AM »
tried it...
art
« Reply #41 on: July 16, 2010, 02:02:38 AM »
Great welcome to 2t's,they do eat plugs,did ya try another,bad spark or not enoupf fuel usualy,compression is also necesary,Did you try to choke it manuely
« Reply #42 on: July 16, 2010, 02:05:59 AM »
...yup...tried all that...nothing makes it fire...
..got good spark, but scoot won't fire...
art
« Reply #43 on: July 16, 2010, 02:13:59 AM »
Didn't you have something grounding out in the beginning,disable kill switch maybe,the reeds have not gotten any worse?Plug is dry?gas down the sparkplug whole maybe,should fire if spark is adequate.more stuff in the pipe  ???
« Reply #44 on: July 16, 2010, 02:19:04 AM »
...plug is very dry, and so is the combustion chamber...
..even though i got fuel dripping out the filter side of the carb, plug and top side of piston are dry...
