Author Topic: OK boys and Girls :D HELP  (Read 1848 times)
Nireen
« on: May 17, 2017, 02:46:38 PM »
My cover that sits over top of the muffler is now wobbling.  I understand this  happens.  How does Kat firm it up? I assume I need something between the muffler and the cover.  But what?
Kat :)
Re: OK boys and Girls :D HELP
« Reply #1 on: May 17, 2017, 03:05:32 PM »
there is a metal spacer with a fire proof washer  around it, if you had it apart it may have fallen off,
« Reply #2 on: May 17, 2017, 03:19:34 PM »
  they use to have a kit with all the parts in it , now 1 piece at a time more bucks for them,   look up a parts for sale Co.  I use     powersportswarehouse.com    you can see what you need,
ole two wheels
  • ole two wheels
« Reply #3 on: May 17, 2017, 04:02:52 PM »
Okay Scooter girl. If the plastic cover is touching the muffler, you will have to scrape and chip it off, cause without the spacers the cover will be toast. Yelp, shore will. ~ Find them spacers.
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
Nireen
« Reply #4 on: May 17, 2017, 04:11:23 PM »
Oh boy.  I think they are there but it is still moving around.
Mac
Kat :)
Nireen
« Reply #5 on: May 17, 2017, 04:43:35 PM »
OK I have all the metal spacers but one of them is missing a rubber to keep it from jumping around.
Kat :)
kneeslider
« Reply #6 on: May 18, 2017, 06:59:25 AM »
To be honest, the spacers, screws and t-collars Kymco that decided to use to mount of a decorative cover is absurd.
It could have been designed to a much simpler method.
2019 Yamaha X-Max 250
Redk
« Reply #7 on: May 18, 2017, 08:08:17 AM »
You might try a local ACE or True Value hardware store...  they have an aisle full of assorted things  where you might find something close.
..  or would that be Canadian Tire ?
redk
mousejunks
« Reply #8 on: May 18, 2017, 09:41:24 AM »
I ripped my cover off because it was loose and painted the muffler black.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
« Reply #9 on: May 18, 2017, 11:24:43 AM »
Good morning,
All of the muffler people-shields move some on all scooters I've  seen.
You're  saying that your shield moves/flexes more than it used to?
Tightening the fasteners didn't work, or they loosened and fell off?
Whatever you use from a hardware store for fasteners and spacers must include fire proof, heat proof item touching the muffler skin.
Kymco sells replacement bits for this.
Not cheap....but will encourage periodic checks of these fasteners the next time around.
« Last Edit: May 18, 2017, 06:07:51 PM by Stig »
Snorvey
« Reply #10 on: May 18, 2017, 11:34:51 AM »
Whatever you use from a fardware store for fasteners and spacers
You have fardware shops in the States?
Wow.
It'll be years before we get fardware stores in the UK  :(
Nireen
« Reply #11 on: May 18, 2017, 02:35:24 PM »
I have all the fasteners but I think I need just one rubber to stop it from vibrating.  They are all snug except for the one that seems to be missing a rubber washer.  Yes it is Canadian tire we have here in Canada. :)
Kat :)
ole two wheels
  • ole two wheels
« Reply #12 on: May 18, 2017, 03:06:44 PM »
Maybe an O ring would work????
Mac
Mac
2012 Kymco DT300
Nireen
« Reply #13 on: May 19, 2017, 06:42:30 AM »
What is an O ring someone's wedding ring LOL
Mac
Kat :)
ole two wheels
  • ole two wheels
« Reply #14 on: May 19, 2017, 03:11:17 PM »
Oh come on, Scooter Girl, surely you jest.---Just in case you are serious, an O ring is a round rubber ring, primarily used for sealing joints. They come in various sizes and thicknesses. If you could find one with the thickness and ID (inside diameter) as the other rubber washers it should suffice. Trying to be helpful here.
Mac
Mac
2012 Kymco DT300
