Author Topic: Oil leak  (Read 4387 times)
vgrafx
Oil leak
« on: May 18, 2017, 03:09:19 PM »
After riding and scooter sits over night I have minor drops of oil under crankcase on oil filter side,
Have checked underneath can not figure out where it's coming from? Any ideas where to check.
Dt300i 6500 miles
update
Spoke to kymco joe at kymco
Oil was leaking small droplets from oil change bolt, seems impossible to get that washer that goes on the bolt, simple fix I used Teflon tape on bolt 3 oil changes no leaks.
« Last Edit: October 22, 2019, 04:03:24 PM by vgrafx »
Re: Oil leak
« Reply #1 on: May 18, 2017, 07:39:04 PM »
  clean and polish the area around drops go for a ride then check for oily spots, my downtown 300i did that at 75,000 Km.  I changed the gasket now waiting for the check up. need to ride???? my scoot is sitting in my friends heated garage,  have a hard time getting to work on it ,.
Mr. Paul
Re: Oil leak
« Reply #2 on: May 18, 2017, 08:22:40 PM »
Just what de dee said, but ride very, very slowly around the neighborhood. If you ride too fast the wind just blows the stuff everywhere. The likely culprit would be the oil filter seal or the oil drain plug if the crush washer is missing or old.
2009 Kymco People 150
1993 Honda Helix
mousejunks
Re: Oil leak
« Reply #3 on: May 18, 2017, 10:11:20 PM »
Clean and degrease the engine from the top down, then go for a few rides. I would check:
- the round cover with a slot in the middle of the engine cover, the o ring can fail. Just retighten if necessary.
- the wires that come out of the top of the right engine cover. They plug into the stator and can also leak being made of plastic.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Redk
Re: Oil leak
« Reply #4 on: May 20, 2017, 02:28:13 PM »
A tip from Honda riders I once knew...
Clean very well, and dry.
Dust with baby powder and make a very short, runup to temp.
Source of small leaks should become apparent.
redk
ole two wheels
  • ole two wheels
Re: Oil leak
« Reply #5 on: May 20, 2017, 04:40:08 PM »
Hello VGRAFX and welcome to the forum. You'll like it. One problem I've had with my DT300 is the rubber hose on top of the valve cover, that is the crankcase pressure re-circulation hose, works it's way off of the nipple and begin to seep oil and then blow off and oils everything under the seat tub. It comes from the factory with one of those dinky little wire clamps. I put a screw type hose clamp on and it worked for a while. After it came off a second time, I really tightened the clamp, all I could with a screwdriver. So far so good. It only comes off after long periods of high speed travel. The higher to rpm, the more pressure is released. May not be your problem, at all, but a better hose clamp is in order, regardless. Just my thoughts.
Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
sotsma
Re: Oil leak
« Reply #6 on: June 29, 2019, 04:39:20 PM »
Hi all
 I am a new rider with a DT 300i abs scouter
after about 10 days with no problems I notice oil leak under the right side near to the filter ( you can see at the photos )
I notice a little opening 8-10cm right from the filter (as you can see on the marks), I think that from this little opening came the oil.
Does anyone know why? What I must fix to stop that?
Downtown 300I ABS '10
Cheetah 50 '09
XT 250 '93
Re: Oil leak
« Reply #7 on: June 29, 2019, 05:20:40 PM »
Is that the water pump weep hole?.....weeping coolant and flowing to the rear, imitating an oil leak?
Or a breached seal in the water pump, mixing oil and coolant out the weep hole?
You DT owners will know.
Miles and years of this scooter?
Re: Oil leak
« Reply #8 on: June 29, 2019, 05:44:58 PM »
Hard to tell there is so much all over. Like they said above...
Re: Oil leak
« Reply #9 on: June 29, 2019, 05:46:10 PM »
That's the weep hole.
sotsma
Re: Oil leak
« Reply #10 on: June 29, 2019, 11:10:14 PM »
I don't think that is the ' Water pump weep hole" , it's outside from water pump , the caps that coming out from this hole is oil not water neither mix (water & oil)
The " Telltale Hole " is on the water pump cover (as I found in service manual )
« Last Edit: June 29, 2019, 11:13:41 PM by sotsma »
Cheetah 50 '09
XT 250 '93
Re: Oil leak
« Reply #11 on: June 30, 2019, 12:48:16 AM »
Wouldn't be the first mistake in the service manual. Pick a model!
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: Oil leak
« Reply #12 on: July 02, 2019, 06:25:24 PM »
Wow that a lot of miles / km on your scoot!
PaulC
